SL/R230: Replacing air filter?
Old Jan 31, 2010 | 03:37 PM
hydropneumatic's Avatar
SL600
How difficult is the replacement of air filters on SL 600? Can it be a DIY or take it to the shop
Thanks in advance
Old Jan 31, 2010 | 05:59 PM
NCE500's Avatar
2007 E63, 2006 C55
RE: SL600 Air Filter Swap
I changed mine last weekend, it is not harder than any other MB I have owned, took me about 15 minutes.
You will need the correct Torx bit size, and be careful when pulling the front engine cover as there are 2 clips towards the center at the back that require a little patience to remove. Other than that, everything was 100% like every other Benz I have changed.
My car had the original factory filters still in place (very DIRTY). After removing the filters, I vacuumed out the filter housings to get all the sand, dirt, leaves etc. out and then installed new OEM replacement Mann filters.
My car runs noticably better with fresh filters, if you are mechanically inclined go for it.
Old Jan 31, 2010 | 07:38 PM
SL600
Are there any clips on the back engine cover or any hidden screws anywere? Does it have flat sheet filters in the box or cones?
Old Jan 31, 2010 | 09:03 PM
ttdang123's Avatar
2004 SL600; 2003 F 360 Spider
These docs should help you. It is a DIY
File Type: pdf
File Type: pdf
Old Jan 31, 2010 | 09:54 PM
SL600
Thumbs up
Thanks man that was very helpful. BTW is there someplace this manual can be bought from or is it only available to MB service?
Old Jan 31, 2010 | 10:04 PM
ttdang123's Avatar
Sorry - I bought it a while back on the internet somewhere to take care of my car. I can not recall where now?
It was a part of the Mercedes WIS system.
Old Feb 17, 2010 | 06:28 PM
zeugtow's Avatar
sl500
Is this the same for a 2004 SL500? I want to change air filters and cabin filter
Old Feb 17, 2010 | 07:30 PM
ttdang123's Avatar
Engine Air filter:
I can not recall the look of the engine cover of a SL500 since I have a SL600. I think they are diff since one is 8cyl and the other is 12cyl
In any case, it should be as easy as removing the cover and unscrew the airbox cover. Just have to be slow and careful.
Cabin air filter:
Should be the same in the SL600 as in the SL500. Search this forum for "cabin air filter" should give you the doc you need.
Good Luck
