SL/R230: Courtesy Light Changing
To open the dome unit, there are a total of 4 clips.
2 on each side of the translucent plastic approx. 45 degrees facing you, and 2 other clips in the front on the solid plastic about 2 fingers from the center of the unit (both sides).
Pry a little bit on the center left clip, then the center right clip to evenly open the unit.
Next is the blinking lights --> If you can live with the blinking LEDs when opening the door, once you drive for 10 seconds or so, both the LEDs come on. I have the deep blue color and dayum.... so sexy!
