SL/R230: 2004 SL500 TRANSMISSION PROBLEMS: WON'T GET OUT OF PARK
Old Oct 23, 2010 | 03:54 PM
chris092183's Avatar
sl500
Question 2004 SL500 TRANSMISSION PROBLEMS: WON'T GET OUT OF PARK
THE PROBLEM IS THAT THE CAR WON'T MOVE OUT OF PARK. IT HAPPENED A COUPLE OF TIMES BUT I WAS ABLE TO GET IT INTO GEAR. THIS ALSO HAPPENED TO ME AT A RED LIGHT SO THE CAR HAD TO BE TOWED HOME. NOW IT IS JUST SITTING IN THE DRIVEWAY AND I CAN'T PUT IT IN THE GARAGE. I DON'T WANT TO DAMAGE THE TRANSMISSION BY FORCING IT INTO GEAR. IS THERE A RELAY OR SOMETHING THAT COULD'VE GONE BAD? PLEASE HELP. YOUR ADVICE IS GREATLY APPRECIATED.
-CHRIS
Old Oct 23, 2010 | 04:18 PM
omar26's Avatar
E55
You can either repair the solenoid or replace the shifter. It's a Fairly common problem. There is a lot of information in the r230 threads on this issue, just search "stuck in park". Good luck
Old Oct 23, 2010 | 04:49 PM
Rick SL55's Avatar
2005 SL55 AMG, 1986 Porsche 930S, 1996 Porsche 993tt
search you just need to change the selector
www.sc3.com.au/monoglobal/index.php?cat=2592
Old Oct 25, 2010 | 02:58 AM
j_belll's Avatar
‘23 EQS AMG
i had the same problem. cost roughly $1300 to fix
Old Oct 25, 2010 | 05:25 AM
gearshifter's Avatar
SL500
Had the same problem, thought it was the pin selector, but it wasn't. For me, it was the unit which electronically controls the transmission; It fried.
$1300
Old Nov 12, 2010 | 08:42 PM
sl500
Thanks guys. I remover the shifter and indeed it is that gear selector lever. I am looking for an aluminum unit. I went to the Monoglobal site but found that they only make a plastic unit for my application. I have the GB3004 gear selector lever.
Here is the link of their levers:
http://www.monoglobal.com.au/Identif...y%20finder.pdf
I also found this seller from ebay who manufactures similar products:
http://cgi.ebay.com/ebaymotors/ws/eB...7330&viewitem=
I will be calling them tomorrow so hopefully I can get the aluminum unit we shall see.
