SL/R230: Oil change intervals?
Old Dec 29, 2010 | 06:27 PM
aaforever's Avatar
W221 S600 // R230 SL500 // B8 A4 // JZZ30 SC300
Hey guys. I have an 2003 sl500 and I'm wondering what is the best times to do oil changes. 3k 10k? Miles 3 months or 1 year? I'm hearing different stories so I just want to get it cleared up. Thanks!
Old Dec 30, 2010 | 07:35 PM
NCE500's Avatar
2007 E63, 2006 C55
RE: Oil Change
I use Mobil1 0-40 oil and change oil and the oil filter every 6 months, regardless of mileage, in every Benz I have owned. I have an excellent Indy shop, they also give the car a check over for free when changing the oil to ensure everything is in good working order.
Old Dec 31, 2010 | 10:27 PM
ohlord's Avatar
Every 10k miles or
as indicated on the fss monitor.
Mobil 1 0w40 syn, fleece filter,reset fss light.
Done
Old Jan 3, 2011 | 07:55 PM
jctevere's Avatar
2012 C250 Coupe
To my knowledge cars in the U.S. don't run on the FSS system, but they use the time/mileage algorithm. Therefore, you should change your oil with Mobil 1 Fully Synthetic 0w-40 every 10,000 miles or 1 year, whichever comes first. Also, you must use a OEM Mann Fleece filter.
The 3,000 mile length is for cars that don't use synthetic and have engine not designed for long engine oil life.
Because oil filter is located on the top, the suction method can be done (as the dealer does) through the dipstick tube on your vehicle. If not, then you do it the old fashion way through the drain plug.
When you change your oil, you can't judge by the color of the oil (as synthetics blacken faster because of additives and the black the color means the better the oil is working). Instead judge by the amount of sludge on your fleece oil filter or thickness of the oil. You can also get your oil tested and they will let you know if you should change sooner.
Generally, 1 year or 10,000 miles is safe and good if you don't drive like a track star. Synthetic has even been designed to last for 2 years on low mileage, so 1 year is a bit overkill. If you have been rough, you can do every 7,500 miles, but I wouldn't do it any sooner.
Old Jan 3, 2011 | 10:35 PM
mtbmtb's Avatar
2003 sl 500 launch edition
use OEM Mann Fleece filter? i picked up a mobil1 filter when i got the oil. should i not use it?
Old May 15, 2011 | 04:23 PM
BENZGR's Avatar
2003 SL 500
I have taken my 2003 SL to two different dealers and both insist that changing my oil more often than every 10,000 miles is a waste of oil and money. I am "old school" and still am not sure that this is the best policy. Comments????
Old May 15, 2011 | 09:06 PM
Rick SL55's Avatar
2005 SL55 AMG, 1986 Porsche 930S, 1996 Porsche 993tt
I change oil/filter every 5k miles.
