SL/R230: turning stock R230 to AMG & Audio Command question...
This may be a relatively dumb question to ask but I can't seem to find any info regarding this matter...
I'm planning to fit AMG body kit & wheels to my R230. Since the original R230 comes with 2 single muffler outlet on each side what do people normally do ? (since AMG comes with 4 muffler outlets)
Does the factory AMG package from Benz include the AMG exhaust system or just a modification done to the muffler tips ?
Secondly, my car doesn't come with the audio command unit with color LCD display it came with a simple cassett/CD stacker unit just like the one in the photo:
If I want to go for a used unit will it work via plug & play (don't need the sat nav working) ? or I need to fiddle with other components? I drive a euro spec car wonder if a NA spec unit work at all & can I fit any unit from a '06 '07 car to a '04 vehicle ?
Thank You!
any help is much appreciated
dayum someone decided to cheap out on it LOL, looks like a joke! I would change the system if I could!
But back to your question. Apparently the cost to implement an aftermarket system would about about $3000. Newer comand systems will not work as the 04 model uses a different cpu.
If you look on my info site (www.mercupgrades.com) it tells you how to remove the wood trim
Then switchover is the case of a little adapter set, a GPS antenna an a COMAND unit.
You can then get the cluster coded so it displays navigation instructions.
If you want to stay "as per factory" that is a nice easy upgrade - but the COMAND that fits in there is now very old, first released in 1999 in the W210 E class.
Richard
Yep, I can't agree more on the stock casset thing ! comon... who still uses their cassetts? HAS TO BE CHANGED
In that case what Audio Command unit should I be looking for? only the '04 unit or anything from '02-'05 ?
As per AMG muffler If I order the original AMG rear box/muffler (according to NEMES1S info, AMG package comes with tips only so I assume this is the genuine part off the SL55) will it sound terrible? I have the first edition SL350 with the V6 in it (245bhp model)
I've finally made purchase on a Comand unit taken off a 03/04 SL350 (same year and model as my car) The item arrived and I found out there are no cables or anything included besides the system. A message from my mechanic came to me, mentioning I do need the set of cables that comes with the Comand unit in order to get it work. My question is, is it true ? or the cables behind my current unit actually fits into the LCD comand unit? ( my current unit is a black & white benz audio system as see in the first post in this thread )
What can I do now? Did I just spent a fortune & realize the Comand unit is useless now ?
Please help
