SL/R230: need help on parts to finish conversion
Old Aug 22, 2011 | 06:31 PM
Arellano_n's Avatar
W211 320 avantgrade sl500 r230
Exclamation need help on parts to finish conversion
hello
conversion is almost car is being painted diamond white but i have 2 problems, on the w211 conversion i did i swap the internals from one headlight to the other so all conector would fit and had no troubls with the light balast or module, i bought the 2 sl63 headlight on ebay 400 each but the headlight came without the light module or ballast, i want to know the parts number or if the ballast from other mb would work ( s class seems to work but not sure http://cgi.ebay.com/ebaymotors/07-10...#ht_1119wt_937) the back seems to match the conector for the headlight! if i cant find a ballast i would have to swap everything from one headlight to the other and that means opening the headlight and messing with everything , im also missing the connector that goes to the headlight the older one is diff. part number? plz help!!
https://mbworld.org/forums/sl-class-...0-project.html
Attached Thumbnails need help on parts to finish conversion-chemicalguys2026.jpg   need help on parts to finish conversion-chemicalguys2022.jpg   need help on parts to finish conversion-chemicalguys2020.jpg   need help on parts to finish conversion-chemicalguys2019.jpg   need help on parts to finish conversion-chemicalguys2017.jpg
