SL/R230: Speedometer cluster change?
Old Sep 30, 2011 | 12:25 AM
Koru_Kinshi's Avatar
2018 E63S AMG, 2003 SLK 230 Sport, 2004 SL 600, 2006 SLK 55 AMG, 1998 E320 Wagon
I was curious on something.
Seeing as how the SL 600 can easily break 160 with the governor turned off...is there a way to swap out the speedometer cluster for something with a higher max speed...for example an SL 55? Or is there a company that makes a *good* speedometer cluster for the car which exceeds 160?
Any info would be helpful. Thanks.
Old Sep 30, 2011 | 06:26 PM
B R's Avatar
B R
2010 Taco
I would think that your digital will read up to 999. Are you planning on going faster than that??
Old Oct 2, 2011 | 12:59 AM
Auraraptor's Avatar
I wish someone would offer a recode to mph for the euro cluster. That way we could have a higher (marked) top speed while keeping the same oem style.
Old Oct 2, 2011 | 10:19 AM
pleeson's Avatar
2022 GLC 300
FWIW, on my 2003 you can change from miles to km in the configuration menu -- not so on the euro versions?
Old Oct 2, 2011 | 10:10 PM
No, no. I meant the actual speedometer needle, heh. I know the digital readout should keep going. It would just make sense...at least in my opinion.
