SL/R230: Problem with wrecked 02 sl500
i am a new sl500 owner from Finland. I bought my car from a place where insurance company's sells wrecked cars. The damage on my car is not so bad. problem is, I cant open the trunk. Batterys are dead because the car have been in storage for long time. I tried this https://mbworld.org/forums/cl55-amg-...d-battery.html. I got power to gauges but when I try to open trunk the red light of the hardtop system in the center console start to blink. Also there is an image of a open top in the display but the top is down. I attach few pictures to clarify. Thanks in advance.
Jari
this will be solved when I get the batteries loaded but is there any other way, because the car is very difficult to move.
I assume you have the correct key :p
The MB dealer will make you a new blade for just a few Eur's . Just supply them with the VIN #.
Try spraying WD40 up in lock .
Maybe a little grease would help.
But to get it open when I use the metal key, I'm turning it anti clockwise, and when I'm holding the key to the left, I then push with the other hand the trunk opening handle.
It's a little tricky, probably because the struts also are very weak, I'm going to replaced them soon.
have you disconected the other battery?
If this is the case then the trunk will not open. If the top is up can you try the with the ignition on, play with the "top" switch to fully close or open until it says top up or down? Then try the trunk.
The battery for the engine start is under the hood, any way of starting the car so the rear battery charges? I apologize if I am off base. Maybe worth a try.
