SL/R230: Torx Sockets?????????????
Old Jun 14, 2012 | 06:22 PM
hooperdoski's Avatar
SL500
I have a 2006 SL500. The valve covers are leaking so I plan on tightening them. When I finally got the engine cover off I noticed the valve cover bolts have a wierd head configuration. It looks like they're torx head bolts which require a torx socket, which I don't have because I've never seen torx headed bolts before.
I need to know if it's a torx head bolt or something different so I can buy whatever tool I need? Is it a torx headed bolt and if not, what is it?
Also, will these torx bolts, if torx is what they are, be metric sized. In other words do they make torx in both metric and SAE sizes?
Thanks.
Last edited by hooperdoski; Jun 14, 2012 at 06:33 PM. Reason: Added additional question.
Old Jun 14, 2012 | 07:54 PM
nsxguy's Avatar
a few cars, few bikes,04 SL55
Just drive your car to your local Harbor freight and buy a set, it should do the job thats what I did when I changed my vc gasket. I think its under 10 bucks
Old Jun 14, 2012 | 07:57 PM
SL500
So you're saying it's torx?
Old Jun 15, 2012 | 12:18 AM
nsxguy's Avatar
Yes sir!!!! But one off those 12 point socket will work too
Old Jun 15, 2012 | 10:05 AM
SL500
Good to know that the Torx will work. Thank you for that info.
As for a SAE socket working, I read a thread that said a 3/8" socket will work, but I tried two different 3/8" 12 point sockets and they didn't work. Maybe I'll try some metric sockets to see if they work.
Thanks again.
