SL/R230: Consumer battery dead,trunk stuck,how to charge?
Old Oct 9, 2012 | 05:33 PM
SL502's Avatar
SL55AMG-CL55AMG
Hi guys,great site you got here,thanks.
Got a problem here with flat consumer battery and no running motor at the moment and no manual key,how do I open the trunk and charge the battery?
Same to the glove compartment it`s stuck.(Car new to me today)03 SL55.
Old Oct 9, 2012 | 05:36 PM
theunderlord's Avatar
(SOLD) 05 E55 Estate. 11 Golf TDi
Only way you can order a key is with proof of ownership right? You'll need the manual key eventually, might as well get on order.
Old Oct 9, 2012 | 05:39 PM
Exotic-metal55's Avatar
PLATINUM SPONSOR
2003 CL55
If your battery is dead, then you should have an auxilary cable under the passenger floor board to hook cables to.
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Old Oct 9, 2012 | 05:54 PM
SL502's Avatar
SL55AMG-CL55AMG
Sounds like a plan EXOTIC-METAL55,I`ll try it,thanks.
Old Oct 10, 2012 | 12:23 PM
jobe's Avatar
sl500
no manual key?! that is odd... every key has metal key inside for cases like this.
Old Oct 10, 2012 | 03:46 PM
SL502's Avatar
SL55AMG-CL55AMG
Yes thanks, you are right,I got a 2002 500 R230 too,so I know this but the problem was I got only the plastic key until today, I did find the metal key in the inside pocket of the door so I did open the trunk and the battery charger is on now,the car had a bad owner so key card and the most is away,and I do NOT get the glove compartment to open? The roof is dead?(Got a extra battery connected)
Old Oct 10, 2012 | 03:48 PM
the sunroof requires a re-initialization yes?
You have already rated this thread Rating: Thread Rating: 2 votes, 5.00 average.
