04 SL600 climate control has no power need to locate the FUSES for it please help??
SubscribeHi Guys,
can any of you take some pictures of you engine compartment fuse box for 04 SL600 on both side for me please?? im trying to see if my stealership has pull some fuse that make my heater/climate control not power up? i lost my fuse map so i cant see which one is which, i went to stealership and ask them to give me an estimate to see how much to fix my ABC, spent a 2 days to take a look and they not even test it yet I got upset and went pick up my car and talk to the GM and didnt realized it stop working til now and of course only realized when need it. cant go back to them because it has been 4 months. and will not go back to them anyways but dont want to bring to another stealership before checking it out myself, so any help would be appreciated!
thanks
thanks
thanks
Maybe this help.Originally Posted by 600RTECH
Hi Guys,can any of you take some pictures of you engine compartment fuse box for 04 SL600 on both side for me please?? im trying to see if my stealership has pull some fuse that make my heater/climate control not power up? i lost my fuse map so i cant see which one is which, i went to stealership and ask them to give me an estimate to see how much to fix my ABC, spent a 2 days to take a look and they not even test it yet I got upset and went pick up my car and talk to the GM and didnt realized it stop working til now and of course only realized when need it. cant go back to them because it has been 4 months. and will not go back to them anyways but dont want to bring to another stealership before checking it out myself, so any help would be appreciated!
thanks
Juha
when you get a chance to look at your driver side fuse box, do you see an F relay as shown on the fuse map, because i dont see mine, is that the cause for no power to my climate control???
Quote:
Hello.Originally Posted by 600RTECH
As I mention yesterday I have not my car here...... Maybe I can check it at the weekend.
Juha
That fuse chart dated 2001 is the same fuse chart that was included in both my 2003 SL55 and my 2006 SL65 tool kits...
The fuse charts were totally wrong and show relays/fuses where there are none and do not show the relays and fuses that are there...
The MB dealer had to wire Germany to find the correct fuse chart for my SL65 so they could locate the charge air coolant pump relay and fuse...
/\ Can you share where those two parts are (coolant pump relay and fuse)? Thanks.
Aaron
Aaron
ExploreSuper Member
Thank you Juha, whenever you get a chance to, appreciated!!
Sorry for the delay.... but here is the picture about the fuse box.
I hope this help you out.
Juha
