SL/R230: 2004 SL350
Old Jan 26, 2013 | 04:21 PM
Kevinl30's Avatar
CLK 240
2004 SL350
Just about to buy 2004 350 SL.Was Sat nav standard equipment?
Old May 2, 2013 | 02:48 PM
Philip317's Avatar
s320cdi /SL350/Slk 230
Hope you didn't buy it- this model has serious problems, in particular the transmission difficulty ( has a 722.6 transmission) and believe me if that problem materialises for you then you are in for a serious fright. The problem can happen when you are on the move, where you loose complete traction ie no power or moving off from a stationery position, and that can be tricky in heavy traffic if you are expecting a surge f power when you apply your accelerator and find that you have no traction - I nearly got amen out with that kind of an experience . There are plenty other good cars out there so be wise and in particular be careful. If you want to read about my case against MB see same under R230 Transmission Problems on Page one of this forum
