SL/R230: Electrical Gremlin
Old Feb 5, 2013 | 07:36 PM
corsair944's Avatar
2015 C63 Coupe
Lightbulb Electrical Gremlin
Hi Everyone?
Just got the 03 SL500 in Dec. Took it to a INDY here in Vegas and he didnt come up with any codes. Heres whats up:
1) Top not working, the handel just flashes red. Roll bar works and realizes the trunk cover is in or out of place.
2) Windows not bumping up and down when opening the door
I can see 1 & 2 being connected, but thought Id mention 3 & 4 since it all started at the same time.
3) rear turn signals not working, removed bulbs and visually look good.
4) tag lights and tail lights are on all the time whith key on (light switch is off)
Today Ive checked fuses, hydrolic fluid level and for leaking cylinders. Rear panels (wings/flaps) on inside of trunk are nice and tightly tucked up. Removed rear cubby behind pass seat and cheked connections & fuses.
I also disconnected both batteries overnight to see if anything would reset.
Ive been reading forums all day and no luck, so here is my cry for help.
Thanks if anyone has any insight
& the electronic key is taking several pushes to unlock the door (batteries are fresh)
Old Feb 5, 2013 | 09:18 PM
Sgooter's Avatar
'14 E350, '03 H-D FXDL
I don't know much about the 03 SL models, but try this:
Check your owners manual for the following adjustments:
ESP reset
Sync (or re-sync) power windows
Old Feb 5, 2013 | 09:28 PM
CrashOften's Avatar
2012 CLS63 AMG pp, 2009 Silverado 2500HD Duramax
Sounds like a simple (but hard to find in some cases) ground issue. Almost all electrical issues that are multiple-system affecting are ground related.
Have a look at this video:
Old Feb 5, 2013 | 09:34 PM
corsair944's Avatar
2015 C63 Coupe
Thanks Sgooter, I did do that several times. Forgot to mention it.
Im really bummed about this.
Old Feb 5, 2013 | 09:43 PM
corsair944's Avatar
2015 C63 Coupe
http://www.youtube.com/watch?v=wcbMuGE3rL4
Crash: thats so me lol
The SL is the wifes car too
I liked the Euro lights in his 300D
I'll poke around for some brown wires tomorrow.
Old Feb 5, 2013 | 09:47 PM
Shifter's Avatar
E55, SL63, ML550
Ground issues , until you work on a mb!! Not really common with the 230.
Old Feb 5, 2013 | 10:23 PM
corsair944's Avatar
2015 C63 Coupe
Thanks Shifter,
Im only 2 months in learning the 203. Ive been twisting wrenches on MB's for 25 yrs. My 1st was a 79 300CD when I was 17 back in tha day
Old Feb 5, 2013 | 10:39 PM
Shifter's Avatar
E55, SL63, ML550
Cool. Check the flaps on the trunk lid that fold in and out when operating the top. If they are not snug against the lid it's ur problem.
Old Feb 6, 2013 | 12:33 PM
corsair944's Avatar
2015 C63 Coupe
The flaps look good. Nice and tight.
The center piece that goes between the 2 flaps appears to be drooping a little.
Old Feb 6, 2013 | 07:46 PM
corsair944's Avatar
2015 C63 Coupe
Today I searched the trunk area for all the grounds and everything looks snug & tight.
I also unpluged the tail lights & removed the tag lights and turned on the key and still no luck.
I still had the lightbulb and visit workshop in the cluster.
My wife said "when that light bulb went away the top worked"
Old Feb 6, 2013 | 10:16 PM
CrashOften's Avatar
I'd check all around the engine compartment for grounds, as well as the rear battery connection, and make sure they're all tight. Back in the day, I'd take a long piece of wire (10' or more) and attach one end firmly to the negative battery terminal and take the other and touch it to various "ground" locations throughout the vehicle. If you see or hear any sort of spark then what you've just touched is not properly grounded. Obviously, be careful around anything that is "hot". You may not see or hear anything, but the isue may go away while you have the ground wire contacting something. It's worth a try.
Old Feb 14, 2013 | 12:38 AM
corsair944's Avatar
2015 C63 Coupe
I was talking to a friend and he mentioned since I was missing the passenger side fuse box cover to start looking there. I have purchased and installed the new cover.
This is what I found and have ordered a passenger side SAM. The whole circuit board was also covered in green slime.
We'll see what happens when it gets here.
Thanks everyone
