SL/R230: xenon lights
Old Feb 24, 2013 | 07:07 AM
eddybeek's Avatar
xenon lights
Strange problem with my sl 500 when i turn on the ignition all lights working fine, when i start the engine and turn on the lightswitch strange things are happening, parkinglights come on but one site of the lowbeam xenons starts flickering for a short time then stops the othterside does nothing ,changed the bulbs but still the same.
anyone an idee?
Old Mar 8, 2013 | 11:13 AM
eddybeek's Avatar
anyone an idee?
Update switched the ignition-units and the highvoltage modules with no result.
put it on DAS today and got two faults in both headlightunits
B1424.... cut off because of undervoltage at terminal 56B
B1425.....multiple cutoff because of un............ 56B
Only in FL headlight B 2575.... the ignitionunit is not inserted or is faulty.
anyone knows if i can switch the complete units? the right-ignitionunit connector has a two wires (bridge connection) more.Thanks
