SL/R230: Wheel Adapters and Fit a non 5 x 112 rim
04 Cadillac CTS-V, 04 MB SL600, 99 Mustang GT Anniversary Edition
Hey Guys,
I have a deal I'm trying to make on a really rare and very cool rim and it's bolted and spaced out for another vehicle. It's 5 x 108 and 40mm (front) and 45mm (back)
I'm looking at getting a wheel adapter made that's 20mm thick and will change my bolt out from 5 x 112 to the new 5 x 108.
My question is about the offset. Since the rim is already 40mm, and I'm using a spacer, am I moving the offset closer to stock (30mm) so with the 20mm spacer, I'll be at 20mm offset. Thus the rim will be a bit more (10mm) closer to the wheel well?
Is this making sense, or have I got it backwards?
Thanks,
SL600MOJO
Thanks,
SL600MOJO
Super Moderator
Received 3,273 Likes
Hey Guys,
Thanks,
SL600MOJO
Thanks,
SL600MOJO
Rear should be fine at 25mm offset.
Pulling the Trigger on the Rims
Well, I'm gonna make the deal and make it work. Thanks to Wolfman for the input. For what ever reason I was struggling with the concept of the offset and the spacer created by the adapter. I'm getting the rims picked up by uShip and delivered this week. They are the OZ Tuner Racing Leonardo III. 20x9 front 20x10 back. I'm going to put Vred's on them 245's front and 275's backs.
The seller told me that I could get an adapter that's a 5 x 4.5 to 5 x 108 and it'll work ok with the mercedes as 5 x 4.5 is really close to 5 x 112. I'm not sure honestly. If someone would confirm that. We will use hubcentrics to accurately fit the MB 66.5 hub and the adapter hole @ 73mm. So they will supposedly fit perfect.
Any additional input would be appreciated.
Thx!!
SL600MOJO
Thx!!
SL600MOJO
Thx!!
SL600MOJO
Thx!!
SL600MOJO
The most important part. Even if you can get 108pcd wheel to 114pcd hub adapter (if 108 to 112 is not available), you still will need Wobble Bolts to "fit" 114pcd hub adapter onto the 112pcd hub, which also means that 114pcd part must be cone seat (which they normally are) otherwise wobble bolts can not be used.
Super Moderator
Thx!!
SL600MOJO
Thx!!
SL600MOJO
With wider rims I would go at least with stock widths if not wider.
I would assume OP wants to use taller than stock tires - 245/35-20 front 275/30-20 (285/30-20 also could be used) rear.
IMHO the most important here is not as much tires' width and profile as the tires' weight. These specific wheels are heavy - about 36lbs front and 37lbs rear (even though centers are forged). Adapters also are a few pounds each. Something to think about.
FYI - I bailed on this rim/hub adapter deal. After more research there aren't alot of people who recommend an adapter situation on such a heavy car. So I bought a set of Giovanna's that are perfect fit, and should have them next week. I'll do a photo shoot once they arrive. Thanks for all the input!
SL600MOJO
SL600MOJO
