ABC block valve electric diagram needed
Subscribe
Jul 25, 2013 | 08:17 PM
Also have C 1525 and C 1526 codes , what these codes means and how to fix it ????any help, and some one has the electric diagram with color wires etc , i have missing conectirs and dont know wich color goes with what connector , i will appreciate for the help! Thanks
Reply 0
Jul 26, 2013 | 04:04 PM
1. With a factory compatible scan tool monitor the hydraulic suspension pressure. System pressure should read around 180 to 200 bar.
2. If pressure is within specification the fault is not current at this time. Check for correct fluid level and let car sit overnight to verify suspension does not leak down and cause car to drop to the ground.
3. If pressure is not correct, first verify correct fluid levels. Inspect system for leaks. Test and inspect wiring at system pressure sensor for damage. Replace sensor with known good component.
4. If pressures are still not correct, suspect faulty suspension pump or other hydraulic fault.
5. Replacement of any hydraulic component requires bleed function "Rodeo" with factory scan tool to remove all air from system. Replacement of strut requires calibration of strut with factory scan tool.
Reply 0
Jul 27, 2013 | 11:52 AM
Thanks Hemi Tom, what abot the electric wire diagram? Any idea where can i get it? I will replace the entire block valve but in my car the conectors are missing and only have loose separate wires with diferent colors and we dont know wich wire go with what conector , the MB local dealer dont replace pieces that you didnt buy fom them , and they ask me almost 3k for the job, i really need help!!!!! Thanks
Reply 0
Jul 28, 2013 | 10:42 AM
I'm afraid I do not have a connector diagram.
Reply 0
Jul 28, 2013 | 11:59 PM
The 'Model 230 STAR Service Manual Library' DVD available from MB has an External Applications tab that brings up an Electrical Troubleshooting Manual with complete electrical diagrams.
Reply 0
Jul 29, 2013 | 06:03 PM
Thanks 4th SL,
Reply 0
Jul 31, 2013 | 01:13 AM
here is the ABC WIRE DIAGRAM FOR R230
http://www.renntechmercedes.com/supp...0_to_02_06.zip
can any body explain or show to me , wich part of this diagram represent the directly conectors to the ABC VALVE BLOCK in order to know wich color go with what connector ?? there is for colors marked in the ABC valve block, red, blue, yellow and green, i will love to know wich colors goes with what connectors
thanks a lot
Reply 0
Feb 18, 2020 | 04:00 AM
Where do I get one? Will it read all issues connected with ABC ?
Reply 0
Explore
Subscribe
Currently Active Users (1)
