SL/R230: ABC to Coilovers conversion: The Ultimate FAQ
I sourced the PS pump, however the PS lines dont line up. The original post mentions this:
"Do i have a need to keep the ABC/Power Steering Pump?
The R230 has a tandem pump that operates both the ABC and the Power Steering system. A new pump is $1360 from Genuine Mercedes and even a used specimen will fetch upwards of $700 at a junkyard.
Luckily for you, once the conversion is completed there is no need for a tandem pump anymore.
I sourced a power steering pump from a 2001 S500 without ABC (any year W220 without ABC should do it).
Two out of the three mounting bolts line up perfectly and the stock lines from your R230 can be rerouted with minimal work....."
It appears that the stock PS lines are used, however how are they rerouted?
Can someone explain what needs to be done?
Looks like they thought of everything !
Complete coil-over kit
https://rebuildmastertech.com/merced...onversion-kit/
they buy your Old system for $1,200 which makes it seem very reasonable..
.Masterbuilt or something, handling vvk, waiting to hear from them..the sl500 came from Florida origanaly...was over 5k to put system on...
I bought the car in Houston Texas..no spanners or info,, I have searched all over the MB site and so far no PDF or anything on shock load adjustment..I know several of these systems have been put on the SL..I'll keep looking, Thanks
...I guess I'll try counter clockwise and see if I can get it right.. thanks again.
My car is a '03 SL500. I have been running coilovers for 5000 miles now so I'll answer any questions once and for all and let's see if we can make a sticky out this thread for future reference.
First of all, let's start with the ABC system.
Yes, it will fail. There are no "if's" but rather "when". The design isn't particularly brilliant and the pressure generated by the hydraulic fluid far exceeds what the seals on the struts and the pump are designed to handle. Hence once it fails, if fails massively. Furthermore, replacing all 4 struts, pump, block and lines will not only exceed the cost of a used SL in today's market, but it will inevitably also fail.
Where do you get the conversion kit?
StrutMasters SL500 Kits
There are two kits available.
The first is the Coilover system for $1595.
For an extra $200 you get a light fix module. The module is a series of resistors that will block the warning from the ABC sensors to the Comand system. That way rather than a flashing red warning that you cannot disable, you simply get a "Warning: ABC Display Malfunction" message that you can click through. Considering Mercedes charges over $2000 for each hydraulic strut, do yourself the favor and get the light fix module.
Do I need to modify anything?
No. The kit is a direct bolt on. They include the hardware to cap off the ABC lines at the struts. Other than that the coilovers mount at the same points your original suspension does.
Is there a kit available for my 55/600/63/65?
Unfortunately there aren't any kits available out there for the different R230 versions.
Is there a sway bar available?
If anyone has it, I have yet to find it. Would the car ride better with one? Absolutely. Does it ride well enough for me not to care? Absolutely.
How does it ride?
Let's start off the bat and say it: coilovers will never ride as smooth as a hydraulic suspension.
Once the ABC is off, you begin to realize just how heavy the chassis is.
The ride is tight but comfortable. The rebound on the coilovers is noticeable but not unlike an E500. All in all, it makes for a comfortable ride that is predictable under hard driving.
I have driven the car from New York City to Arizona with no trouble whatsoever and have logged on over 5K miles as of today.
Extra bonus: You get to use regular power steering fluid from Autozone or Walmart rather than having to track down CHF 11S at $30 a liter.
So there it is.
If you have any other questions, feel free to ask away and I will do my best to answer.
https://mbworld.org/forums/sl-class-...er-struts.html
and substitute the word "CEIKA" with "Strutmasters" - the only difference is that CEIKA is adjustable and Strutmasters is not (that's why I don't like Strutmasters), everything else can be the same. The photo I posted above is that of the quick connect on the car end, plugged with the rubber plug, this is the "line people tell you to plug". The strut disconnects by pulling on the quick connect by hand. After that you just remove and ship the strut. You don't do anything with the strut end of the connector, which remains connected to the strut and not plugged.
That is $4.00 (four US dollars) per strut.
Which I think is a good price for maintenance free struts which can be adjusted multi-way for spring softness, shock absorber stiffness and for car height.
I'm under an impression you wanted to block off quick connects and keep ABC under pressure - a VERY BAD IDEA which would make your car unreliable and could get you stranded.
