SL/R230: ABC to Coilovers conversion: The Ultimate FAQ
Old Dec 22, 2021 | 08:17 AM
  #176
Tomcat SL's Avatar
2004 SL55 AMG
Originally Posted by Gene Fiorot
I believe it is known here that VVK does not make Sway bars. However it is very easy to determine the diameter of the bar. Maybe I am wrong but the RMT bar is thicker than the MB 350 part.
Thank you...the plot thickens!
Ps-The SL is (part time) in Pensacola.
Old Dec 22, 2021 | 08:25 AM
  #177
Tomcat SL's Avatar
2004 SL55 AMG
Old Dec 23, 2021 | 07:52 AM
  #178
Tomcat SL's Avatar
2004 SL55 AMG
Thanks X 2
Old Jun 16, 2023 | 05:45 PM
  #179
nuge's Avatar
Lurking
Is there a kit now available for the SL65?
Old Jun 16, 2023 | 06:06 PM
  #180
Gene Fiorot's Avatar
SL500
Check with these guys. They know their stuff......https://rebuildmastertech.com/merced...bc-suspension/
Old Jun 16, 2023 | 06:58 PM
  #181
Hary Gahtoe's Avatar
R230, C5 Corvette Convertible, Audi Allroad, Lexus RX350, AE86 Hachi Roku
As my bars were being built from VVK they mentioned a V12 sway bar package and Coilovers
FYI;
VVK R230 SL500 front bar is very large diameter
Can’t say enough their fit and finish
They are worth the cost and I have no affiliation with them either
Old Jul 6, 2023 | 12:24 PM
  #182
WhipMeister's Avatar
2003 SL500
Does anyone know if VVK is still around? I can't seem to reach anyone there.
Old Jul 6, 2023 | 03:41 PM
  #183
Tylerhayles's Avatar
Sl55 amg 2002
3-4 months ago they was i have tried contacting them for a long time over email , never a reply
i have a friend in the states who popped through to the address and they was still trading he gave me the owners number , sean I believe it was we exchanged a few text message but was abit slow
Old Jul 7, 2023 | 01:04 PM
  #184
2003 SL500
Success! (Whew. was getting worried.). Sean called back and said they had received a bad batch of bars coming from their fab shop. Promised to send me another.
Old Jul 7, 2023 | 01:20 PM
  #185
Size Does Matter And So Does Engineering
Chef; unless you’re going to “soup up” the handling you need to add a “real” sway bar not just one that fits unless that’s the goal
I strongly suggest using VVK set over the RMT bar because the rear bar on RMT uses the OE 350 rear bar which is significantly smaller than the VVK And the mounts on the VVK are much stronger. Don’t forget the cost. The RMT set is too close in price for the lesser sized and smaller mounted set.
Its best benefit is aimed at those in a hurry
In the big picture you can buy mismatched bars or get the best out there. It pays to get matching Fr &Rr sway bars in a car with a decent level of control and quality
Like many people here I struggled with the $ figure but it all came down to the value and I’m glad I did
Old Jul 7, 2023 | 09:32 PM
  #186
Tomcat SL's Avatar
2004 SL55 AMG
I strongly suggest using VVK set over the RMT bar...
I too went with VVK and could not be more pleased!
Old Jul 8, 2023 | 01:04 AM
  #187
SL500
The RMT front swaybar is as thick or thicker than what is out there. Rear Sway Bar ? You must already know the argument about needing swaybars in general are needed with a coilover mod. Well I drove both with and without. The RMT bar is huge. Make a difference around 40 -65 mph ? Somewhat flatter on off ramps. I like it. Rear Sway Bar ? I just don't see the need. I am open to change my mind.
Old Jul 12, 2023 | 01:37 PM
  #188
OK Like the girl in the bar said; How big is it Gene?
With sway bars and handling it's matching or balancing both Fr & Rr to a car. The rear factory bar is quite small so even though you are increasing the roll resistance in the front you can also cause a tail happy car by leaving a small bar in the rear.
Again I'm not affiliated with VVK but the front bar is 30mm and the rear is 20mm which is likely larger and more matched than using a standard SL350 Rr and the RM front
What many forget is as good as a single large front sway bar is; a better handling RWD car sports a hefty rear sway balancing out the front to keep the rear from stepping out
Old Jul 12, 2023 | 07:01 PM
  #189
SL500
I will measure it first chance I get Gene
Old Jul 14, 2023 | 03:52 PM
  #190
k_b_k's Avatar
plan to buy an sl or cls 55
Hi everyone!
New here, new to MB, don't even actually own one yet, but I'm considering buying an SL55. Since I'd plan to keep it for a very long time, I'd be planning to delete the ABC as I've read up on this topic and it seems that a lot of people have done it and are very happy. I do wonder however, if VVK and their products are still available. Looks like I'm not the only one who's having a hard time reaching them, and since I'm in Europe it's not really an option to pop over to them So can you guys confirm that they are still in business and the conversion kit is available, and works as advertised? (Or if there are any alternatives worth mentioning...I'd prefer something that is designed, fabricated and tested for the exact car..)
Thanks!
Old Jul 28, 2023 | 05:11 PM
  #191
elMacko's Avatar
SL 500 2004, Ford F-150-2014
Tony, I can see your links are OK in the connection with the lower arm, but the connection with the sway bar end is open to the elements..! I wonder how long it will last before you start listening to clicking noises! I fabricated mine too but mine are mounted over polyurethane bushings and the sway bar is mounted from the rear of the subframe like it is mounted on the E430. Also seems like that bar is pretty hefty...is that a 30 mm bar? My bar is 26 mm, but the distance from the attaching point to the torsional section of the bar is shorter, meaning less resisting momentum!
Old Aug 16, 2023 | 06:00 AM
  #192
Charl Viljoen's Avatar
Sl65
hi Colin
I removed all the ABC parts and installed KW coilovers kit , please direct me to who coded your system as I have multiple faults for ABC and SBS brake system which we cant get cleared. regards CHarl
Old Aug 16, 2023 | 10:38 AM
  #193
SL500
BenzNinja
Old Nov 9, 2023 | 12:57 PM
  #194
Get_around's Avatar
SL55
Coil over conversion - ABC warning lights?
Originally Posted by Colinporter
I'm using the BC Racing coilovers & sl350 antiroll bars which work fine. W220 s500 ps pump which bolts straight on if you get the triangle bracket. As for the ABC warning light i have had the ABC removed from the computer using star diagnostics. I've basically had everything associated with the abc removed from the car.
Curious - did the Star ABC removal get rid of ALL the warning lights/alerts?
Old Nov 9, 2023 | 05:50 PM
  #195
Tom Manning's Avatar
2005 SL 500 R230
You need STAR with developer mode to code out the ABC. Not available from the dealers here for some reason, perhaps the clones come with developer mode?
Old Nov 29, 2023 | 05:09 PM
  #196
Sergey84's Avatar
W140, R230
Hey guys, I don't want to start a new thread, so I'll rather post a few questions here:
1) What PS could you install in your SL600 or SL65 AMG when performing a coilover conversion? It seems every video on YT is about either SL500 or SL55 AMG. They are using a PS pump from ML55 that fits perfectly. I'm not sure but I suppose V12 cars have different geometry and different mounts for PS pump. So I wonder if there is a solution for V12 cars where you can only have a single PS pump instead of tandem pump?
2) I haven't figured out if I need anti-sway bars or not (I know there is a thread about it and I'll read it) but they say you need a new engine mounts in order to provide enough clearance. So I wonder what could happen if you install the sway bars but later your engine mounts degrade? Will sway bar push against something and even crack it?
Thank you.
Old Nov 29, 2023 | 08:12 PM
  #197
So if serious are you about a coilover conversion the information is not hard to find at all.
A simple search turns up several links
Power Steering Pump - 2001 Mercedes S600 5.8L V12 - Bosch 6465-05686880
Old Nov 29, 2023 | 11:36 PM
  #198
Sergey84's Avatar
W140, R230
Thank you for your reply. I'm sorry, but I can't confirm the fitment. Please could you share a link for that store where you found it? I have 2005 SL65 that has M275 V12 engine. Cars with this engine were made since 2003. Everywhere I search for a PS pump for like 2005 SL65 or S65 or similar model I see tandem pumps that start from around $400 and up...
Old Nov 30, 2023 | 07:35 AM
  #199
llcoolbenz's Avatar
2003 S430 , 2002 CL500 , 2007 S550, 2003 Yukon Denali XL
Power Steering Pump For V12 R230 SL600/65
https://www.goldelementautoworks.com...00-2-1l-diesel
Old Nov 30, 2023 | 07:41 AM
  #200
JettaRed's Avatar
Veteran: Army
I never did this but am wondering if the tandem pump could have its plumbing changed to just recirculate a reduced amount of hydraulic fluid to and from the reservoir since that is what it does anyway with the ABC in place. Couldn't the feed and return lines just go to the fluid reservoir instead of out to non-existent valve blocks and shocks?
