SL/R230: Yet another ABC problem..
I went to my local garage, where they told me that my front-right strut needed replacement. I order a pair from Arno (I figured it would be cheaped if I was proactive) and replaced both. For about 6 months everything was good (except of my rear battery complaining that "convinience functions unavailable" after a day or 2).
Suddently, I got the ABC warning again. My (new) mechanic told me that STAR has 2 errors again for the front-right strut and it's sensor. I asked my mechanic to change the sensor and take it from there as it is cheaper and I do not think that it is possible that the same strut went bad again. After changing the sensor, no error, until I press the button for ABC to raise. Although the car goes up normally, the warning appears again and I cannot make it go down unless I switch off a few times.
Is it possible that this has something to do with the installation of the strut?
Does is sound like a bad strut or pump or it is more likelly that the sensor/installation is not reporting the correct high or pressure?
Any advice on how to procceed? (The suspension struts are under guarantee from Arno but I still have to pay the mechanic and the shipping cost)
I ended up getting the ABC Pump itself replaced, the warning lights reset and have never had any dash error readings ever since. So, you may want to look into getting the actual pump replaced.
Try to have your mechanic (or yourself) find a rebuilt one. You can probably find one for around $500.
Hope this helps!
I can't say that your experience will be the same as mine, but all I can say is that I was dealing with ABC issues for a couple years and I drove the car like that even though the Mercedes Dealer told me it would all of a sudden just die on me one day and probably right in the middle of the road in rush hour traffic.
It never did that even when I had issues I figured out ways around it. If the system wouldn't raise, I would turn the car off, unplug the battery to trick the system and then it would raise again. I could talk all day about this, but anyway that's what worked for me.
1. Replaced my front right strut after an ABC warning appeared followed by an ABC fault
2. My rear battery appeared to be dying and I got "convenience functions unavailable" warning
3. I changed my battery and I was still getting the same error (but not as frequently)
4. The ABC warning came back for the same suspension strut after a few months
5. I changed the sensor, but no change
6. I noticed that the car was not properly aligned, i.e. right side was higher
Is there anything that I should try before changing the strut again?
Can it be a sensor connection problem?
