SL/R230: WIDE-BODY SL600 V12
I have had a custom radiator built in order to allow more space for the CAI. It will be a quad CAI with 2 larger intakes behind the center grille and 2 smaller intakes going to the DRL area..
We will also be running 2 inter cooler pumps and 2 fans all going through a control unit which can adjust each pump and fan speed independently depending on the temperature that you program each item to cut in at, they will also be variable speed so they can ramp up and down individually as required.
I am hoping we have now done enough to counter the v12 heat issues and allow the new upgraded turbos to create the power we are looking for.
We should have dropped around 300lb of weight along the way and 150-200lb more when I decide to do the coil over conversion.
I have also given the go ahead to change the cluster to the 220mph version to complete the look.
The last thing I am looking at is the SLR gear stick with the red fighter pilot flip up starter button to retrofit. I will see how that goes.
These are the wheels but mine will be black. They are 10.5" front and 12" rear, 22lb front and 24lb back. They are the lightest I could find.
Okay... Good luck
That wheel looks really good much better than you have at the car now...
I'm also interesting about the new clusters...
Can they make Black Series type of clusters?
I have few picture's about them.
The cost retail is around £1,400 but you should be able to get it under £1,200
Okay thank you.
I have already the SL65 AMG rpm cluster but need the speedo cluster.... then its fine.
I made a deal with them... 250 USD for the work.
I can ask about this to.
Did you order Black series or SL65 AMG cluster. I think they look different?
Hope you can weight them with the tires on to....
Which Michelin tyres do you have.
I didn't order the black series as it was much more expensive.
Typical weight is 27lbs.... but who really nows.
My Michelin's are at the front Pilot sport and at the rear Pilor super sport.
Are you going to use Silicon tubes or something else with your intake setup?
They will be powder coated red also, they are due to be installed on the 18th so I hope to get some pictures of the front end and the install in progress.
Im gone take of the T-branch and made a test. I have an idea about that part and If I have right Im gone modified it.
Eurocharged have flown two guys from Houston over who will help with the tune tomorrow and Friday. I am due to pick the car up Saturday
I am still waiting for my HRE's to arrive.
