SL/R230: SL600 Cold air intake project
Old 09-02-2015, 03:42 AM
  #326
Ekselent's Avatar
SL600 / SL450 (107) / E350 / BMW M5 E60 / BMW 745i (E23) / BMW X6M / Toyota Hilux 4 WD/ Honda CBX 10
Originally Posted by cm60k
As i think; SL600 uses "External" fuel pump, while fuel pump in SL65 "In tank",,
but why MB switched injectors from SL600 "Siemens/Deka" to "Bosch" in SL65..??
ZAYED,,
Bosch dealer told me Bosch injectors work better in small opening times and more linearly than Siemens Deka.
I asked because why change Manufactory ?.... I could pretty well ask for bigger Siemens Dekas but now when I know I'm gone choose Bosch.
I think Ebay is the cheapest place to buy??? Any Ideas...
Same number but EV14 type of injectors.
Old 09-02-2015, 04:46 PM
  #327
Ekselent's Avatar
Originally Posted by Ekselent
Hello members.: ;
I have been at a Dyno Dynamics dyno with my car.. : )
- gear box is not slipping. : )
- engine power 533,7 Kw . 725 hp at about 5200 rpm
- torgue 1170 Nm
As I have mention several times earlier the power is there!!!!! : ).
And it was.... : ).
Thank you to al of you who have belive me al the time.
And for those who not....
" sorry guys, sorry guys" have a nice day and sleep well.. : )
Now I have a new problem ... The engine run to lean at full bost.... So new injectors then I get even more power.... : ).
(Low read Dyno Dynamics)
Have a nice day...I have a long trip bak at home... 550 miles.. : )
Hello Members....
Here is a data log video clip regarding my dyno run. You can follow:
-Boost
-Timing
-Intake temp
-Torque
The intake temp was surprisingly well remained stable throughout the run.
The video going step by step that can be better monitored.
Ambient temp was around 26 C / 78 F.
https://www.youtube.com/watch?v=kIF5...ature=youtu.be
Juha
Old 09-03-2015, 05:30 AM
  #328
cm60k's Avatar
00 C200 & 00 C55 & 06 SLK55
Very good info. Juha, didn't know that Bosch has wide opening times than Siemens /Deka, that may one of good reason that MB switch them to Bosch..!,
that dropping power is little bit strange!!,
do you know if ECU data/file reading properly during high ITA with -fuel range..?!?!
ZAYED,,
Old 09-04-2015, 01:48 AM
  #329
Ekselent's Avatar
ZAYED,,
Hello.
I think it have something do with the emissions???
Honestly I dont now.... IAT vs fuel range
I remember only one thing. I was at top speed with my car and after a while the engine fault code flash up at the speedo and at the same time it shut down one half of the engine. Stopped the car and open the trunk, take of the battery - cable and put It bak after a while. Start the engine and all 12 cylinder run fine.
After that I took the car to Mercedes and they look with the star after fault codes. They found one fault code... The IAT was to high and therefore its cut of 6 cylinders so its dont damage the engine. I had lot of air in the IC systeem.
But as you now at my dyno run :
- boost was lineary and fine all the power range
- IAT was also great
- A/F ratio show to lean.... It was so lean so the tuner wonder if't even possible? At the dyno power curve you can see the power drop a little at the higher rpm and go up again at the last rpm range. I think another 10-15 hp is there at the top when the A/F ratio is adjusted fine....
Old 09-04-2015, 03:37 AM
  #330
F1BHP's Avatar
sl600
So no misfire codes on star? It is unusual for it to cut the cylinders as it would just pull timing to deal with the IAT's, then go into limp mode after that but it doesn't drop the cylinders.
It sounds like coils to me, or ignition module. Have you changed either since you started modding?
Old 09-04-2015, 07:50 AM
  #331
Ekselent's Avatar
Honestly I dont remember anything about misfire codes its one or two years ago... I had the tune and coolers and scorpions.
Now I have change :
- both coilpacks.
- al 24 sparkplugs
- Ignition module also ... It was not even broken but I change it also so I can drive with the car without ignigtion probleems in the near future...
Juha
Old 09-04-2015, 09:53 AM
  #332
cm60k's Avatar
Assuming air/fuel ratio need to re-calibrate,
need to see the ECU/file, to make sure everything saved properly in the ECU/E-prom..!!
ZAYED,,
Old 09-04-2015, 11:52 AM
  #333
F1BHP's Avatar
sl600
I thought you were saying that these problems were recent, you should be good if you have done all those items.
Old 09-04-2015, 03:13 PM
  #334
Ekselent's Avatar
No not this time.... Now its only the A/F ratio and Im sure when I change bigger injectors the A/F ratio is going to be fine for sure.
Im gone look with the star if it have some info stored about the A/F ratio from my run...
Its strange because the IAT show fine ..... It would heated up the air in the engine if to much lean.....
The engine power dyno run curve show something hapen at the higher rpm??
BTW when are you going to update your thread? Any pictures about your intake setup?
Old 09-04-2015, 03:17 PM
  #335
Ekselent's Avatar
ZAYED,,
Im gonna look at that with the star if it can show something?
Old 09-04-2015, 03:20 PM
  #336
NEMES1S's Avatar
2005 SL600, 2016 ES300h, 2012 Hayabusa
I would suggest checking fuel pressure all through the power band, could have a dying pump
Old 09-04-2015, 03:24 PM
  #337
Ekselent's Avatar
ZAYED,,
Old 09-04-2015, 03:54 PM
  #338
Ekselent's Avatar
Yes we also thought it first so we made a fourth run with fuel pressure meeter and a osciloscope to look if the injectors is full open at full boost.
So the pressure was 3,8 Bar but drop a little at higher rpm range... I think it drop a little because al injectors was full open and ECU try to do the best...or fuel began to lather.... The power curve drop a little in same rpm range so it must run to lean.
If you look at the osciloscope display (down ) you can se two line ends approaching each other and finaly take a contact at higher rpm range and its mean the injectors is full open. So the difference between both liene ends show the opening times.
So I think the pump is fine...
Sorry if I don't have show the video clip earlier when we measure it... But here its
Old 09-04-2015, 08:15 PM
  #339
F1BHP's Avatar
sl600
I am still trying to get mine back on the road, I got the turbos back today for the third time and they should go in tomorrow. I will see what kind of shots Ivan get of the intake but it is difficult to see them.
Old 09-04-2015, 10:05 PM
  #340
BlownV8's Avatar
Received 1,078 Likes on 865 Posts
E55, GLS450, GL63, GLE350
What did you have done and why did it take three times?
Old 09-05-2015, 11:55 AM
  #341
Ekselent's Avatar
Three times ?
I would have wanted to se the pipes before they installed them?
It would have been interesting to see how you have solve the fitting problems. What are the pipe size and so on?
When its the dyno day? Have you already dynoed the car with the first two turbo setups?
Old 09-05-2015, 12:05 PM
  #342
Ekselent's Avatar
Today I tested my X6M first time at the mile.
I got 156,8 mph / 250,88 Km/h.
Ist a good speed or bad?
Juha
Old 09-05-2015, 01:35 PM
  #343
F1BHP's Avatar
sl600
I have 4 x 3" CIA pipes.
The first set of turbos was an upgrade of the sl600 turbos which have a very unusual turbine wheel size, with two different sizes. The compressor wheel we used was very large and caused blowback issues while trying to be tuned. Two things may have been the problem. One the manifolds could not get the air out quick enough or. Two the size relationship between the compressor wheel and the turbine wheel may have caused issues.
The second time the sl65 turbo was used, we used a slightly smaller billet compressor wheel upgrade than the first time along with the sl65 has bigger evenly sized turbine wheels. We started to tune the car as Eurocharged USA has sent 2 guys over to do my tune. They had the car over 700BHP with A/F still peaking in the 11's at this point a squeak was starting to be heard so we had to stop. All the normal pulleys and belts were checked and the noise seemed to be coming from the drivers side turbo.
So now the turbos have been rebuilt again however when they were pulled apart they said they saw no evidence of any issues. So third time lucky. I hope the turbos were installed today and we will do the final dyno runs and tune on Monday.
Jerry from Eurocharged USA was very keen to keep going and said he thought close to 800BHP was within reach, we shall see. This dyno is also the lowest reading dyno around us so I will probably do a few different dyno pulls once the tune is finalized.
Old 09-05-2015, 03:07 PM
  #344
Ekselent's Avatar
Okay thank you.
Sound very interesting and I hope you get what you want.
Old 09-06-2015, 02:06 PM
  #345
BlownV8's Avatar
The problem you will find and you have already experienced is the exhaust manifolds won't flow the air out from the increased flow. You really need to increase the interior size of the manifolds or.fab entirely new manifolds.to see the benefits you want. From what I understand, 800 hp is the most you will possibly see from the stock manifolds.
Old 09-06-2015, 04:20 PM
  #346
Ekselent's Avatar
Tomorrow we will see if he achieve the target.... we all hope so...
In my opinion 800 BHP or HP is a lot.
Juha
Old 09-06-2015, 05:59 PM
  #347
F1BHP's Avatar
sl600
I do not think that it will get to 800hp, this was a comment made by the tuner however I will be very happy with 750hp.
As I have said before for me the goal was not peak hp as a different turbo setup would probably have been used. I want power that comes in early with little lag and will stay strong for a long track session, I have no interest in creating short term power.
If I can get 750hp with those perimeters I will be satisfied, anything more would be a bonus.
I do have the original turbo and manifold from the 600 which I may have a play around with to see if a solution to all our problems can be achieved however right now I just want the car back on the road.
Old 09-08-2015, 03:42 PM
  #348
Ekselent's Avatar
Hello Members.
Today I have been contact with Marcin regarding the fuel pump.
Marcin told me Mercedes use two different pump pressures. 3,5 bar and 4,0 bar.
So my pump (3,8 bar) is week ( as Blown mention earlier) or the filter is dirty or my pump is 3,5 bar pump.
Im gonna look which pump is at my car.
Second thing.... When I change the bigger injectors I need also a new tune from Speedriven.
Im very happy because Speedriven respond fast....
Juha
Old 09-08-2015, 06:03 PM
  #349
Ekselent's Avatar
News...
- SL65 AMG injector produce 445 cc /min. at 3 bar. ( 0,94 cc/min / 43,5 Psi)
0,445 L/min * 12 (injectors) / 0,5 * 100 hp * ,85% = 900 hp.
0,94 USg/min * 12 (injectors) / 1,05 USg * 100 hp * ,85% = 900 hp.
So the max flow suffice to about 900 hp. The 85% means injector max opening time. ( this is how it reported from the manufacturer)
I have not still found any info about SL600 Siemens Deka injectors???
- SL600 injector produce ??? cc /min. at 3 bar. ( ??? cc/min / 43,5 Psi)
???? L/min * 12 (injectors) / 0,5 * 100 hp * ,85% = ??? hp.
???? USg/min * 12 (injectors) / 1,05 USg * 100 hp * ,85% = ??? hp.
So we are not so far away anymore.... : )
Juha
No info from Siemens Deka.
So we try with same formula as we use at AMG 65.
Injector flow.
230L/60 min/12 cylinders=0,319 cc / min.
So the injector flow 0,319 cc / min.
- SL600 injector produce 0,319 cc /min. at 3 bar. ( 0,68 cc/min / 43,5 Psi)
0,319 L/min * 12 (injectors) / 0,5 * 100 hp * ,85% = 650 hp.
0,67 USg/min * 12 (injectors) / 1,05 USg * 100 hp * ,85% = 650 hp.
So the (STOCK) max flow suffice to about 650 hp. The 85% means injector max opening time. ( this is how it reported from the manufacturer).
Now when I have an Speedriven tune the opening time has also been changed for sure. How far I do not know.. Maybe to 90% to 95%???
If it so then we have following suffices
- 90% = 690 hp.
- 95% = 727 hp.
These calculations also strengthened my engine power... I now my engine run to lean and my calculations confirm this also. The injectors is not big enough.
These calculations are only indicative but I think over these values can not go. These is MAXIMUM values and in practice these values can not be achieved when there are so many variable factors, but the indicative yes.
I have done these calculations according to the hope that someone has learned something about these things and this is the way they do in practice,...
Juha
Old 09-17-2015, 03:44 PM
  #350
Ekselent's Avatar
Injector flow.
- 90% = 690 hp.
- 95% = 727 hp.
I have done these calculations according to the hope that someone has learned something about these things and this is done in practice,...
Juha
Hello Members.
Today I have ordered a new fuel filter.
- MANN (Manufacturer)
- WK 720/1.
Im gone change this first and measure the fuel pressure again.
If this does not help then Im gonna buy a new pump.
I need the 4 bar also.
Quick Reply: SL/R230: SL600 Cold air intake project
