SL/R230: R230 Front Strut Dust Cover Replacement
Old Feb 25, 2016 | 01:17 AM
Hary Gahtoe's Avatar
R230, C5 Corvette Convertible, Audi Allroad, Lexus RX350, AE86 Hachi Roku
I have a worn out front strut cover and wanted to know if anyone has replaced theres.
I've tracked down an SL550 front strut cover replacement kits and told by an Indie that it is a fit.
Mercedes repair kit 2213300085
I'd appreciate input from experienced members or if you've seen a site with corresponding info
Old Dec 31, 2016 | 05:50 PM
Wayne Drayer's Avatar
09 550SL
All 4 of mine were torn and falling apart.
With less than 50,000 miles. Replaced all 4 struts due to the torn "boots" and Mercedes split the total cost parts and labor with me.
Old Jan 1, 2017 | 12:53 PM
Happy New Year Wayne.
That's great the service dept. met you 1/2 way on cost. With coming from Florida; for all four to be replaced at <50 k mi. is earlier than the average.
Our 04 car has >95 k mi and rears are still in good shape.
Did anything else need replacing?
Old Jan 1, 2017 | 07:55 PM
09 550SL
Nothing else was damaged...yet. Mercedes had concerns about something else, can't remember what exactly but the regional tech guy told the dealership what to do first and document that issue so Mercedes, if necessary, could be replaced later. It's been 6 months without any issues.
Old Jun 25, 2017 | 12:03 PM
kaigoss's Avatar
2007 SL550
Hi, can you confirm that this part fits an SL550? All online resources I have found say no. Thanks!!!
Old Jun 25, 2017 | 11:55 PM
No. I cannot.
A prudent search might be Arnott MB rebuilt struts and cross reference S,CL CLS with R230, 231 to see if; even though valving may vary the bodies use the same housings
Also
Check OP date. This was a long time ago. When I posted this #was for an SL550. I cant deny or confirm present www listings.
Search long enough and you can find almost anything.
Good Luck
Old Jun 26, 2017 | 12:26 AM
#'s change.
There is a current listing for an SL550 front boot and it's MB oem
You need the boot and have a choice of buying OEM metal retaining clips or simple black zip ties
Old Jul 2, 2017 | 07:47 PM
kaigoss's Avatar
2007 SL550
Well I came up empty searching the net for replacement strut boots/covers for my 07 SL550. Fortunately though, I know German so I started weeding through German sites as this problem surely must exist in the fatherland as well.
I came across the following site which in detail lists part numbers and backwards compatibility of certain parts, confirmed by a member from another forum, which I probably cannot name here.
So here it goes, this is the info I was able to gather:
Rear strut covers: They are (reportedly) the same for all SL 230 and 231 models. The part number, available as of May 2012, is 230-328-00-92. There are 2 snap rings that hold the covers in place, and their part number is 003-994-12-40.
Front strut covers: (reportedly) the lower strut cover for R231 models is backwards compatible with ALL R230 models. The part number is 231-327-00-92. On the above linked site under 1.2 you can find photos comparing the original strut covers (the ones you cannot get a direct replacement for) and the R231 covers. There is one difference, as in the bottom opening is larger and shorter, and the word is that this "exposes" more of the lower aluminum "spring plate", and the recommendation is to spray the exposed area of the spring plate with "spray wax" (not sure exactly what is meant with this but maybe someone can chime in). The upper clamp is part number 001-995-06-35 and the lower one 001-995-07-35, however they say you can use stainless steel screw clamps if you want.
Below is a screenshot of the parts I just ordered. I hope this helps someone, and I will certainly report back once the parts are installed.
Attached Thumbnails R230 Front Strut Dust Cover Replacement-screen-shot-2017-07-02-7.40.43-pm.png
Old Jul 3, 2017 | 11:47 PM
That part is available thru US sources as well and you can use black zip ties instead of the SS clamps but there's also SS zip ties
"Spray wax" would be a generic term for paraffin based undercoating
http://www.mbpartscenter.com/mercede...me=dust-shield
Old Apr 24, 2018 | 04:42 PM
kaigoss's Avatar
2007 SL550
I actually have not installed these yet. Called up a local MB indy and he said it would be at least 10 hrs of labor to replace these. Sounds like a lot, so probably around $1000 -$1500. Anyone have experience with the actual amount of time a skilled tech would need to do this on all 4 struts?
Old Apr 24, 2018 | 10:58 PM
Is The Juice Worth The Squeeze ? Depends. Size; Big Boys
Most prudent people would say FN!!
Step 1:
If you absolutely have to shield the strut get generic strut cover on ebay. Slice it vertically. Use some silicone and zip ties and Bob’s your uncle
Or; buy a two piece CV joint set.
Step 2: Miller time.
Save the oem dust shields for when the struts pack it in
Old Apr 25, 2018 | 12:17 PM
kaigoss's Avatar
2007 SL550
Step 1:
https://youtu.be/H6WkRa6Z0pM
Haha, definitely I agree with step 2
Called another MB shop and they advised against it. Said they needed to basically remove and reinstall all the struts and they did not want the liability. I understand that, but why would you need to remove the struts, can't you just disconnect the control arms and slip these on from the bottom without removing the struts?
I also called the MB dealership and surprisingly they said they would do it for $450 in labor. That doesn't sound too bad, and I'd feel "safer" having them do it.
Opinions?
Old Apr 25, 2018 | 06:18 PM
ozc204's Avatar
2003 SL500
Opinions?
looking at the PDFs it does look like you could slide off the bottom which is obviously the way as with the quote of four fifty from the dealer
I found my RR torn so am also on the "hunt"
Absolutely love this car but catching up on maintenance issues is a right royal PITA
Old May 8, 2019 | 06:06 AM
Stevie Wildey's Avatar
sl 500 fully loaded r230
any updates on this guys, i have ran into the same problem, im in the uk, im torn between getting them imported from china or using r231 ones, surely somebody has done this repair as it is very common?
thanks guys any advise appreciated
Old May 9, 2019 | 04:36 PM
MBCO's Avatar
2015 SL550 & 2012 S550 4matic
What PDFs are you referring too? I would like to replace my covers as well and would be interested if there were step by step instructions.
Many thanks,
Old Dec 29, 2019 | 06:47 PM
Connect2us's Avatar
SL550 and E400
Sick
What is with the picture of the GUN to a scared dogs HEAD ???? Are you that sick in the head? And yet, you call yourself a PASTOR ?????????
Old Dec 29, 2019 | 10:51 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
It's from a cover of the National Lampoon:
https://en.wikipedia.org/wiki/Nation...oon_(magazine)
Old Dec 30, 2019 | 08:59 PM
An Essay on Criticism
"A little learning is a dangerous thing;
Drink deep, or taste not the Pierian spring :
There shallow draughts intoxicate the brain,
And drinking largely sobers us again."
Alexander Pope
Wow. I knew someone might not understand the depths of an inside joke but don’t get too self absorbed by narrow minded internet driven meme’s.
Not only am I truly a Pastor I volunteer at a local animal shelter and currently care for two foster pets. I Also have volunteered at our local food bank.
I have not nor will I consider malintent against anyone or thing. The avatar is not meant to invoke hate or harm. It is poking fun at how **** and narrow minded some folk view life, thats all
When the original photo ran it was front page for National Lampoon.
Don’t take my word butt; I highly doubt Ryan Reynolds shot, stabbed, decapitated all those actors in Deadpool either. Just sayin’
Old Dec 30, 2019 | 10:27 PM
Connect2us's Avatar
SL550 and E400
Rubber Boots
For what it's worth.....
A little measuring on the top and bottom can help you get a cheap rubber boot for any struts.
I have an older Bentley and covers cost hundreds. A BSA front fork cover set worked perfectly.
Old Dec 30, 2019 | 10:50 PM
Precisely. The R231 boot from MB is a close alternative. Ooorr... try contacting Arnotts. They rebuild our struts plus many others
Good Luck
Old Aug 11, 2020 | 02:03 PM
hawgdawg50's Avatar
'07 SL550
strut bellows kit
Good Luck
Read through the thread, saw many suggestions but no final resolution. Found and ordered a bellows kit on ebay for about $120 (unfortunately, it's Chinese). I plan on disconnecting the lower link and sliding them on. I'll follow up in Sept when done. (I don't get in a big hurry usually.)
Old Aug 17, 2020 | 12:22 PM
samble's Avatar
SL55AMG
You can buy replacement rear strut covers from Mercedes for £40 apiece part number A2303280092, for the front you have to buy the whole strut
Hope this helps
