SL/R230: 2009 SL550 hydraulic oil leak
Old Nov 16, 2016 | 04:52 PM
klwsparks's Avatar
2009 sl550
retractable hard top leaking over the right side window when top is activated has worked fine since I owned it just started has it been leaking the whole time and I just didn't notice it until the levels got lower?
Old Nov 16, 2016 | 08:57 PM
El_Toro_33809's Avatar
2003 SL55; 2001 SLK320; 2005 C240
The seals will fail. That probably just started. Here is a link to fix the issue:
http://www.ebay.com/itm/01-12-Merced...lWNn-R&vxp=mtr
Tim
Old Jul 29, 2017 | 10:20 AM
LOU002's Avatar
SL550
[QUOTE=El_Toro_33809;6971498]The seals will fail. That probably just started. Here is a link to fix the issue:
Tim Has anyone done a "How to" on replacing the seal?
Old Aug 2, 2017 | 11:36 PM
carguyshu's Avatar
2003 E55, 2003 SL55, 2014 CLS63, 2018 q50 Redsport, 1968 Camaro SS, 1999 Trans am Firehawk
buy a rebuilt one from top hydraulics. you're going to waste a bunch of time and money trying to do it yourself compared to the $65 a rebuilt front latch costs (the most common failure)
https://www.tophydraulicsinc.com/en/21-r230-sl
Old Sep 25, 2019 | 10:44 AM
TQuick's Avatar
2007 SL 550
This just starting happening to me... what did you end up finding/doing?
Old Sep 25, 2019 | 10:46 AM
TQuick's Avatar
2007 SL 550
Angry Where Leak?
My roof is leaking over the right window as well... can this be coming from the front lock? Dealer is quoting almost $2k to fix!
Old Sep 26, 2019 | 08:56 AM
bobterry99's Avatar
'09 S600, (2) R129 300SLs, '03 SL500, '03 SL55
It surely is coming from the front lock hydraulic cylinder.
The cylinder can be removed and replaced in about 2 hours time if its hydraulic lines are cut. If you are going to pay to have this repaired, I'd find a shop that is willing to proceed in that manner and who will use Top Hydraulics to rebuild the cylinder. The cut lines can be restored using "couplers" from Cabriolet Hydraulics. Cost of this repair method would be c. $500.
