SL/R230: OBD2 Vs Diagnostics Port
Old 12-04-2016, 02:51 PM
gwelliott's Avatar
SL600
I purchased a STAR/Xentry tool from Stardhul on this forum. My intent was to clear an SRS light I have on the dash which kicked on after my battery went dead.
When I connect the tool through the OBD2 port the system states that it cannot access the ABS module (note many other, but not all, modules are accessible).
I read on other post for a different model Merc that you need to connect through the STAR diagnostics port (14-pin or 32-pin) in order to access all the modules. Is there another port connection on the R230?
Old 12-04-2016, 09:16 PM
MBworld Guru
Rudeney's Avatar
Received 1,002 Likes on 870 Posts
NO LONGER ACTIVE
What model year is your car? If it's pre-MY2005, it may be a problem with the multiplexer on the SDS unit.
Old 12-05-2016, 12:46 AM
gwelliott's Avatar
SL600
The build date on my SL600 is 12/2003. If the MY is the issue with the multiplexer is there a solution to this?
Old 12-05-2016, 07:59 PM
bobterry99's Avatar
'09 S600, (2) R129 300SLs, '03 SL500, '03 SL55
No, there is not. You most likely were sold a faulty multiplexer. Far less likely would be a faulty cable. The fact that there is currently no username "Stardhul" may be another indication you have faulty hardware.
Old 12-05-2016, 09:13 PM
next2pool's Avatar
2003 SL500, 2016 ATS, 2016 CTS 2015 Volt
If you can access some modules but not the ABS module makes me think that your Star tool and multiplexer are fine. I suspect your ABS module may be bad and not communicating. However, I thought you were having trouble with the SRS module.
Old 12-05-2016, 10:35 PM
MBworld Guru
Rudeney's Avatar
NO LONGER ACTIVE
When you buy a Chinese clone SDS, there several versions of the multiplexer you can get. There is "C3" which uses a hardwired RS232 serial port connection to the computer, or "C4" which uses a wifi connection to the computer. C3 is probalby the best as there are fewer compatibility issues, plus updates to SDS have "balcklists" that can refuse to communicate with known clones multiplers.
With the hardwired C3 multiplexer, there are two versions. The cheapest is a all flat box that looks like this:
The better version looks like this:
When talking to pre-MY2005 cars, the multiplexer uses a different protocol. In the cheap version of the multiplexer, there are capacitors that tend to ail and it wiill refuse to communicate with some of the pre-2005 systems. It will likely still function perfectly on MY2005+ cars. The systems that fail are ABS, SRS, EIS, ACC and instrument cluster. I think the SAMs and TCU and ECU usually still talk.
Old 12-06-2016, 12:23 AM
gwelliott's Avatar
SL600
Check that username....Shardul.
Most of the systems you mention are the ones I can't access. Ugh. Anyone want to buy a slightly used multiplexor
Old 12-06-2016, 02:30 AM
bobterry99's Avatar
I'll give you something for it in the hope that I can repair it for use with my '03 car. If you like, send me a PM with what you need to ship it to Georgia.
After reading Rodney's post and a post of mine from 2010 I think it is likely that your multiplexer will work fine with an '05 or newer vehicle.
Old 12-06-2016, 07:55 AM
next2pool's Avatar
Never had a problem on my 2003
Old 12-06-2016, 11:26 AM
mekantor's Avatar
2003 E55 AMG; 2013 GL550 4Matic; 2003 CL600
Have you checked the fuse for that module?
Quick Reply: SL/R230: OBD2 Vs Diagnostics Port
