SL/R230: Using the Aux port for iPhone (my V60 Bluetooth alternative)
Old Jan 2, 2017 | 12:09 PM
JettaRed's Avatar
Veteran: Army
This may be old news, but I discovered that by using the Aux port (inside the glove box) to attach my phone, the car speakers and microphone work!!! Yippee! Hooray! Etc. Instead of spending $200 on a puck, I can used the Aux port. And, for $15 on Amazon, I can get a great Bluetooth receiver/transmitter to connect. The MPOW Streambot Mini works great and sounds just as good as using a cable to connect.
Old Jan 2, 2017 | 12:20 PM
next2pool's Avatar
2003 SL500, 2016 ATS, 2016 CTS 2015 Volt
Yes--I did the same and use a wireless bluetooth transmitter--it works great and the sound quality is great as well.
Attached Thumbnails Using the Aux port for iPhone (my V60 Bluetooth alternative)-img_2550.jpg
Old Jan 2, 2017 | 03:20 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
I don't believe the AUX port has mic wiring - just speakers. My guess is that your phone's mic is picking up your voice. Regardless, that's a good solution.
Old Jan 2, 2017 | 04:31 PM
moretech's Avatar
2003 sl 500
Hey JettaRed tell me more about this! I do not see any ports in my 2003 sl 500 glovebox, or maybe I do not know what to look for. The new phone stuff is getting way beyond me. Update, I do see a small hole in the left side of my glovebox! Is this it? Hard to see. Looks like a small screw. I've never noticed this as a "port" thanks for any more info.
moretech
Old Jan 2, 2017 | 06:45 PM
next2pool's Avatar
Yes the aux input plug is the small hole in the LH side of the glovebox. Whatever is playing with your phone will play over the command unit including music, Siri and your phone conversations.
Old Jan 2, 2017 | 07:39 PM
JettaRed's Avatar
Veteran: Army
moretech
You found it! What looks like a screw is the phone jack.
Old Jan 2, 2017 | 07:40 PM
JettaRed's Avatar
Veteran: Army
I didn't think so either, but the people I call say I'm loud and clear. I will try to put my phone in the glove box and see if they still say so.
Old Jan 2, 2017 | 09:27 PM
moretech's Avatar
2003 sl 500
Thanks everyone, my son-in-law who is a real phone nut person is coming over to see what is happening with this jack deal. I must say in 2 years I had no idea about any of this phone stuff. So many features in this car I am still discovering. thanks to all!!
moretech--maybe lesstech!
Old Jan 3, 2017 | 01:42 PM
Heatwave's Avatar
Veteran: Navy
2007 E350; 2018 GLE350
Thanks for that, Mo ... I'm going out to check inside my car's glovebox. I know there's an a/c vent in there, but I didn't know there's a jack also. Owning an MB is always a learning experience.
Old Jan 4, 2017 | 12:26 AM
telrush's Avatar
2004 SL500 2015 ML350 Bluetec
Yes, I discovered this nice feature awhile ago. My solution was to "blackbox" a device using the Fusion BT100 for Bluetooth streaming. I wanted it to power on when the car was running, so I hard-wire the power to the Fusion device to the cigarette lighter. The only issue I had with this was the noise that was introduced by the car's electrical system which caused an annoying variable hum. I solved this by adding an inline PAC SNI-1/3.5 3.5-mm Ground Loop Noise Isolator which cured the line hum. amazon
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Hope this helps if others might have the same issues.
Old Jan 4, 2017 | 11:12 AM
Heatwave's Avatar
Veteran: Navy
Just checked my '07 R230's glovebox: screws around the frame of the box to affix it to the dashboard, and an a/c vent ... but no aux port, no nothing. Nada.
Old Jan 4, 2017 | 04:05 PM
next2pool's Avatar
I recall that only the earlier SL's had the aux in jack. Even if you have one, it's a pain to find the aux input in the radio menu. When you do however, it works very well.
Old Jan 4, 2017 | 05:03 PM
dRockSL55's Avatar
MBs: SL55, GLK350
the aux input is only found on 03-04 SLs
Old Jan 5, 2017 | 04:04 PM
moretech's Avatar
2003 sl 500
from moretech
I got the right connector cable from my son-in law for the phone, it all works just fine!! I'll be darned! Always some new thing to discover in this car.
Old Jan 6, 2017 | 03:35 PM
El_Toro_33809's Avatar
2003 SL55; 2001 SLK320; 2005 C240
Great find. Initially I couldn't find how to access auxiliary in the command, but luckily I have the manual and have what I need now.
Tim
Last edited by El_Toro_33809; Jan 6, 2017 at 03:47 PM. Reason: Answered my own initial question.
Old Jan 6, 2017 | 03:54 PM
moretech's Avatar
2003 sl 500
For me when I plugged the phone in using the appropriate cable the screen on COMMAND changed to AUX PORT. Ready to go as is. Also you find it in the SVC menu (where I never go) at the bottom below change clock settings---see (AUX). Click on it and there it is. Then plug in phone and click on sound and it should come thru just great.
moretech
Old Jan 6, 2017 | 04:08 PM
moretech
Thank you very much. Appreciate the help.
Tim
Old Jan 8, 2017 | 12:55 PM
jfutty's Avatar
looking
Hi. I am a new owner of an 08 sl550. I do have the Bluetooth connection for phone but want to know the best way to connect to stream music. I do not see any aux or even iPhone connector. Any help appreciated.
