SL/R230: SL55 Radio Problem
Old Feb 10, 2017 | 10:21 AM
CGF512's Avatar
2005 SL55 2014 E350 Wagon
SL55 Radio Problem
I own a 2005 SL 55 that I have had for nine years. I am having trouble with the radio. It is not working most of the time. If I drive the car for about an hour to 45 minutes and the turn on the radio, the radio, CD changer and GPS will generally work.
If I turn on the radio after starting the car, it will work for about ten seconds and the stop. Occasionally the radio frequency will remain on the screen, vanish within 10 seconds and the radio will shut down. Other times the screen will come up blank and then shut down. So, about 90% of the time the radio is no longer working.
I have contacted a couple of car radio places and the responses are mixed. One suggested a diagnosis and a radio replacement with a total cost of a little over $2K. Another suggested a radio replacement at $3 to $4K. Neither seemed to have seen enough of the SL’s to really give me confidence in providing a solution to my problem. The amount of money seems a bit high. The car is 12 years old and I love it. It’s in outstanding condition. I plan to continue driving it for at least two more years.
Has this happened to anyone before? If so, what did you do to fix it?
Old Feb 10, 2017 | 11:01 AM
Vader1's Avatar
2004 SL55 AMG
Yes. I purchased a remanufactured Radio from ebay and replaced it myself. Pretty easy to do actually. cost me 300.00
Old Feb 10, 2017 | 01:40 PM
CGF512's Avatar
Thanks for the reply! I have considered that. However, it was mentioned that some fiber optic issue may be causing the problem. Would another reconditioned radio address this issue?
Also, did a Mercedes dealer have to perform any sort of computer identification procedure to make your new radio work?
Old Feb 10, 2017 | 01:48 PM
Vader1's Avatar
2004 SL55 AMG
Yes, if the radio components from the prior vehicle do not match with your components. I've attached a document for you to use to determine the components.
File Type: pdf
Old Feb 12, 2017 | 06:33 PM
BlownV8's Avatar
E55, GLS450, GL63, GLE350
Sounds similar to a problem I had with mine. Turned out the amp was bad.
Old Feb 17, 2017 | 12:43 PM
CGF512's Avatar
I think the command diagnosis screen codes could be quite useful. Do you have to pull the radio out of the care to check them?
Old Mar 8, 2017 | 03:59 PM
Vader1's Avatar
2004 SL55 AMG
No, just follow the instructions on the PDF I uploaded.
