SL/R230: Oil leak after oil change
Old Mar 16, 2017 | 12:23 AM
crehop's Avatar
2015 S63 Coupe C217, 2008 C63(X), 2009 C300(X), 2003 SL55(X) , 2013 S550(X)
Hey guys, I just got an oil change at one of those national chains and he said " wow this is really on there tight it won't budge... " then "wow that's on there good" then after what seemed like a while and him going up and down 2 times he changed the oil then said " you have a leak down there" I thought he meant like a minor leak that was wicking oil or something, but now there is a good half a quart of oil on the driveway....... there wasn't a single drop before that.. any idea what he did (I haven't gotten a chance to crawl under yet, but any suggestions for what he was cranking on I suspect it was the wrong thing... )
Old Mar 16, 2017 | 09:26 AM
kbob999's Avatar
'20 X5 M50i; '17 Ram 3500; Golf Cart; Bikes; Scooters
Stripped the drain bolt? Forgot the washer?
You need to go back and pull the plug and see.
Old Mar 16, 2017 | 12:23 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
This is why I change it myself, from the top.
Old Mar 16, 2017 | 01:23 PM
crehop's Avatar
from the top? please share how.
Old Mar 16, 2017 | 03:22 PM
Heatwave's Avatar
Veteran: Navy
2007 E350; 2018 GLE350
crehop: Google for "Mityvac 7201"
And check this vid:
Old Mar 16, 2017 | 07:35 PM
pfarah77's Avatar
2008 SL550
I think that's how the MB dealers are doing it now. At least on the two I've had/have...
Old Mar 16, 2017 | 07:37 PM
Ghostty's Avatar
2005 SL500, 2015 CLS400
Considering the oil change is $150 at the dealer - i don't even think twice about dealer vs national chain shop ( but, of course, always to do it yourself if you know how).
Old Mar 18, 2017 | 09:23 PM
bbspoolside's Avatar
2007 Gl450 2006 cls55
Check the top of the oil filter housing it's plastic and it's easy to crack it without the correct tool or ability
Old Mar 21, 2017 | 05:50 PM
moretech's Avatar
2003 sl 500
let us know how it turns out.
moretech
Old Mar 22, 2017 | 07:08 PM
crehop's Avatar
UPDATE: so it just stopped leaking all of a sudden.. I cleaned out the engine really well with de-greaser, pulled all the underarmor plastic and cleaned them with degreaser, and then waited, ready to spot the leak.. I drove over an hour and parked it... left it... put newspaper down... not a drop.. Im thinking he may have over filled it? He put in 9.5 quarts (is that too much?) and is there an overflow valve somewhere that woulda just dumped oil? (there was a LOT after the change enough to get my hand soaked by putting it in the puddle) now it does have a small cloud of white smoke when starting but no more after that (didnt have this before the oil change) and I read that it could be from too much oil also.
Old Mar 22, 2017 | 07:12 PM
ItalianJoe1's Avatar
2003 CL 600
Too much won't cause a leak, most likely he spilled oil somewhere and it was running down, as they don't just stop leaking on their own. 9.5 is a bit overfilled, yes, and can cause some excess smoke as the foamed up oil is drawn into the engine and burned off.
I'd say don't go back to this guy again but hopefully you've already reached that point.
Old Mar 22, 2017 | 07:19 PM
crehop's Avatar
"I'd say don't go back to this guy"
never will, im just glad he poured it somewhere and there wasn't a more serious issue that would cost a lot of $$
Old Mar 22, 2017 | 09:03 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
What car is this? Your profile says you have a MY2009 C300, but this is the R230 (2003-2012 SL) forum. If you have an SL500, 9.5 quarts is about 1.5 too many, and yes, could cause leaks and smoke. You need to get it at the right level.
Old Mar 22, 2017 | 10:53 PM
moretech's Avatar
2003 sl 500
Is this an 2003 sl 500 (R230)? Are you in the right forum? What does the dash display tell you about the oil level? Do you know how to pull it up? See the manual if not. It is easy to do. I believe it can tell you if overfilled but I have never overfilled mine. It can also tell you if 1 or 2 quarts low. It says OK when in proper range. Mine takes about 7+ qt with draining via the pan bolt. The pan bolt is way far back near where the 2nd and 3rd panels meet. I agree it is way overfilled! Way overfilled. It really bugs me when you pay for something and it is not done right.
moretech
Old Mar 22, 2017 | 11:13 PM
crehop's Avatar
I have a 2003 SL 55 AMG so this is the right forum, it was saying 1 quart too full, but I got it on level ground an it was saying oil ok, so maybe it has an overflow valve somewhere ?? Or it I wasn't too over filled
Old Mar 23, 2017 | 09:47 AM
moretech's Avatar
2003 sl 500
I think that model has 2 drain plugs on the pan. One up front also due to oil pan shape. The new smoke cloud bugs me. I'd be tempted to drain a quart and see what the dash display says about the level then. I'm no expert but the indicator may be in a gray area where it is just almost to reporting overfill but not registering it yet. If a little less oil in pan solves your smoke problem you are home free. This indy is definitely "off" the list. Other forum members may comment on the 2 drain plug deal.
moretech
Old Mar 23, 2017 | 04:11 PM
Heatwave's Avatar
Veteran: Navy
Regarding the oil stains: it's easy to try adding new oil too quickly. It'll back up in the "pipe" and spill down the side of the engine and onto the underneath pans. Don't ask me how I know.
Old Mar 23, 2017 | 04:44 PM
crehop's Avatar
Old Mar 23, 2017 | 07:50 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
The SL55 holds 9 quarts of oil. As moretech stated, you have two drain plugs. If both are not drained, then the engine was overfilled.
Old Mar 23, 2017 | 08:09 PM
crehop's Avatar
Thanks moretech and rudeney I'll empty some oil and try it again
Old Mar 23, 2017 | 10:46 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
I'd order a dipstick and get an accurate measurement.
Old Mar 31, 2017 | 12:00 PM
crehop's Avatar
So the dumbass at the oil change place only removed one drain bolt and then proceeded to overfill it by 2.5 quarts (probably more because i had a huge puddle in my driveway...) oil reading just kept saying "observe waiting period" no matter what untill i took out 2 quarts on a hunch.. then it said (oil overfilled) so i took out anothyer .5 quarts now it says oil ok... the oil removed was still black (they didnt really change any) and now i gotta go to the dealer... lesson learned..
Old Mar 31, 2017 | 02:02 PM
moretech's Avatar
2003 sl 500
Glad you got it figured out. This is a good thread and keeps all of us mindful about errors made by mechanics unfamiliar with our cars. And!- shows the forum can be a real benefit to us all.
moretech
