SL/R230: ABC Question
Old Apr 7, 2017 | 07:03 AM
Dave3359's Avatar
2017 S550 cabriolet 2007 SL550 , 2012 C300
ABC Question
Getting ready to take my car out of storage I'm going to do an ABC flush and filter I'm thinking of replacing the accumulators but I want to know if I should replace them before the flush or after the flush. The car is a 2007 SL 550 with 28,000 miles The car runs perfectly I have no ABC issues do you think I should replace the accumulators. Also need to do brakes all the way around are the calipers Pistons push in or are they the screw in style Pistons thanks for all your help I appreciate any input
Old Apr 7, 2017 | 09:20 AM
Heatwave's Avatar
Veteran: Navy
2007 E350; 2018 GLE350
1. If the ABC system is working OK, and if the pentosin is still clear green and at the proper level on the dipstick, I wouldn't replace accumulators or anything else. Just drive it and enjoy it.
2. Are you getting a brake pad warning sensor alert? If not, you might consider leaving the pads alone. But you have eyes on the scene and are a better judge of the pads' condition. The brake pistons simply push in.
Good luck, Mate.
Old Apr 7, 2017 | 01:10 PM
mercy-me's Avatar
Veteran: Army
2012 E350 4Matic P2
Good luck, Mate.
Agree wholeheartedly! If the car is running perfectly, let sleeping dogs lie! The color of the ABC fluid will tell you a lot about the condition of the system. The darker the fluid, the more that the system is shedding. I would look for a deal on Pentosin then do your flush economically at your leisure.
As to the accumulators, they are definitely a maintenance item but at 28K miles it seems a bit premature to change them out. You will know when they fail because you will see a sudden drop in fluid reservoir volume and the ride will become very harsh. I changed both of mine at 107K and the rear was ruptured, front was not. They had both been changed previously as they were not MB but Corteco. Ride quality improved immensely in the rear.
All in all, you have a very low mileage example and as heatwave said, enjoy, enjoy, enjoy!
Bob
Old Apr 7, 2017 | 05:19 PM
Dave3359's Avatar
I have all the Pentosin and the filters to do the ABC flush but I've been told and read that the life expectancy of the accumulators are about 10 years so I figured as long as I'm doing it maybe I should just replace them I don't want to wind up stranded on the side of the road Also I have visually check the pads and there's not much left to them that's why I just want to do the brakes and be done with it. Thanks again guys for all your input and support this website is very informative and very helpful
Old Apr 7, 2017 | 05:59 PM
bobterry99's Avatar
'09 S600, (2) R129 300SLs, '03 SL500, '03 SL55
Originally Posted by Dave3359
...I've been told and read that the life expectancy of the accumulators are about 10 years...
What is the source of this information? Mercedes or an authority on the subject? If you read it on a car forum be aware that a lot of "factual" information is nothing more than an expression of someone's guess or their opinion.
...I don't want to wind up stranded on the side of the road
If all of your accumulators were to fail it is very unlikely that you would end up stranded, Dave.
Old Apr 7, 2017 | 06:31 PM
Dave3359's Avatar
Smile
I guess I'll leave well enough alone just flush the system and change the filter thanks again for all your input top-down weather is finally here
