SL/R230: Drivers Window
Old Apr 9, 2017 | 11:24 AM
flittlejr's Avatar
2011 SL550
Smile Drivers Window
My drivers window when I raise it first comes up about 3 inches and stops. Then 2 try goes all the way up and then I raise the rear window the 2 inches to seal. Is there a reset?
Old Apr 9, 2017 | 11:51 AM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Try pulling fuse #9 (left side panel under the hood) for a few minutes. This will reset the door controller. You'll then need to re-sync the windows with the door closed. Pulling up fully on the switch until the glass raises to the top, then hold for five seconds. If this does not work, you may have a bad door controller or a problem with the window regulator.
Old Apr 9, 2017 | 12:10 PM
flittlejr's Avatar
2011 SL550
Smile Thanks
Thanks fast answer I'll go downstairs to garage and try right now. Frank
