SL/R230: ESP switch inop
2005 SL 600,2002 M3,1993 Vette!
ESP switch inop
05 SL 600
when I press the ESP switch I don't get the triangle on the instrument panel anymore
MBworld Guru
It's either the LED in the cluster that has failed, or the switch itself. It should be easy enough to check the LED - floor it so you break the wheel loose and watch for the indicator. If that works, then it's the switch itself. I'd remove the center console panel and check the wiring.
MBworld Guru
Oh, that's right! I forgot abut the lamp test. So, since it's working, I'd take a look at the switch. Here's the WIS doc for center console panel removal:
http://benzbits.com/R230/CenterConsole.pdf
