SL/R230: Buzz noise while pressing brake pedal BEFORE startup [VIDEO]
Recently started making an odd sound BEFORE startup. After I get into the car and press on the brake pedal this noise is coming from the engine bay [VIDEO] - https://www.dropbox.com/s/09j1o3z5ep...artup.mp4?dl=0
This noise is happening before I even push the Start button on the shifter. Any thoughts? I have not yet been able to determine if this happens before every startup or only after the ones where it's sitting a while.
I just noticed something else interesting, after I took her out for a spirited run I pulled into the garage and after I shut the car off the same (Brrrrrrrr) noise came back. So I can verify BEFORE startup and AFTER turning ignition off. Now I need to determine if this is every time or only after she is sitting for a while.
So the consensus so far is that this is normal? I suppose the supercharger pulley squeak is considered normal too so why not right?
(dielectrics grease did fix that)
