SL/R230: Rear Window Replacement for a 2004 SL55AMG
Old Jul 14, 2017 | 09:14 AM
sguelpen's Avatar
SL55AMG
I get water in the boot and was trying to replace the seal (between window and trunk) of the rear / back window when I discovered that the metal underneath the seal was rotted (rust).
It seems the only way to repair that is to replace the entire window / glass component. A new OEM part cost about $2,600 but I see some used ones on Ebay for about $300.
My question is how difficult is it to replace that window?
Any insights would be greatly appreciated.
Old Jul 14, 2017 | 10:34 AM
kbob999's Avatar
'20 X5 M50i; '17 Ram 3500; Golf Cart; Bikes; Scooters
Pretty easy task. I removed my rear window in order to peel off the tint which had bubbled.
First - prop the top open with a 12" long 2x4 in the center.
Remove the trim both sides by snapping off the clips. They will likely need to be glued back on.
Disconnect the wires to the defroster glass.
Find the 2 bolts each side of the rear glass at the hinge, and loosen them up.
Get a helper to hold one side while you remove the nuts/bolts. Then switch sides and remove the other bolts.
Slide your window out toward the rear and replace in reverse.
Probably an hour round trip.
Good luck!
Old Oct 15, 2023 | 08:45 AM
carboy2800's Avatar
SL55 AMG
Good luck!
I know this is an old post but I just replaced the back glass with a used one I got from ebay as mine was also rotted out at the bottom. When you removed yours and reinstalled, did you have any issues with fitment once reinstalled? the back of my roof where it meets the glass, the roof sits up too high. Almost as if the roof is not sitting fully forward. I am not sure exactly what needs to be adjusted.
Old Oct 15, 2023 | 09:00 AM
JettaRed's Avatar
Veteran: Army
Could this be the issue? The WIS instructions are in document AR67.20-P-3000R. There are some additional instructions for adjustments in the document. I just don't know if they apply.
Old Oct 15, 2023 | 10:23 AM
carboy2800's Avatar
SL55 AMG
Yes I saw that after the fact. Not sure if that is why I am having the issue. I am assuming a new glass comes with those brackets already attached but not sure how removing the 4 bolts really affects the geaometry of the glass to the roof.
