SL/R230: SDS Redirect of Headlights
While I was resetting my TCU (god knows where it started) I somehow inadvertently set the headlights to automatically come on at startup. I looked thru body for lights, gauges, etc, not openly found.
Anybody know how to reset the light switch to use auto, on/off and parking would greatly appreciate the help.
Hary
Hary
Hary
Hary
It is also possible that you inadvertently set you car to the Canadian standard. Then DRL are always on and can not be turned off. But I would think that instrument readings would have change to metric, if that was the case.
Thanks Alk247.
Turns out the SDS mainframe before even starting MB vehicle catagories it had COA. Adjusted back to USA and all is good
Thanks for the reply
Hary
Hary
