SL/R230: Location of FM amplifiers
I looked in each side under the dash and the kick panels but didn't see anything. I would like to try and hook up a FM modulator hard wire for aux and Bluetooth.
The only installs I've seen are the gateway's replacing the CD changer.
Any pointers would be greatly appreciated.
Thanks,
Jeremy
Thanks,
Jeremy
You will need a couple of adaptors for Mercedes style connectors. You can get those at any car audio store. It also might depend on what modulator you have. Mine were basic Mercedes to normal antenna and a normal antenna to Mercedes.
I used the fuse block on the passenger side behind the seat to grab power from the 5 amp fuse to the command system. So it is switched 12v.
Thanks,
Jeremy
Jeremy
