SL/R230: COMAND Screen Replacement
Old Aug 3, 2017 | 08:02 AM
db2001's Avatar
SL500
Hello -
My 2005 SL500 screen recently started showing odd small, random botches of a few pixels in various places on the screen. I purchased a replacement screen and have removed the COMAND unit from the SL before.
Does anyone have any documentation on doing the COMAND surgery to replace the screen?
Thanks in advance -
David
Old Nov 2, 2017 | 11:46 PM
jtlswan's Avatar
2005 SL600
Bump......I need to do this to mine. Where did you get the screen David?
Old Nov 15, 2017 | 04:07 PM
db2001's Avatar
SL500
Off of ebay. I've not had the courage to pull the original and do the surgery yet.
Old Nov 18, 2017 | 08:41 AM
Anders Lindgren's Avatar
r230 2003
Hi i did it. It is not easy If you not dabbled with electronics before
Old Jul 23, 2019 | 01:22 PM
850csi's Avatar
--sold Sl55--
Bump... anyone else have any insight? My screen appears to be washed out or otherwise damaged (from the sun? It was a Florida car) and needs to be replaced. I’d like to DIY it.
Old Aug 21, 2019 | 05:04 PM
Frederick NL's Avatar
2005 R 230 SL350 (M112 3.7). Sold the 1966 W113 230SL recently
According to a German R230 forum, the specs for the screens are:
NTG1 Sharp LQ065T5AR01
NTG 2.5 Toshiba LTA065B0F0F
Don’t take my word for it... check before you order
Old Aug 21, 2019 | 07:25 PM
JeffR230's Avatar
R230
I would also be interested in this. Isn’t there a shop in Florida that repairs this? The screens seem to be more expensive than the entire Comand unit. Why is that? Can AliExpress be trusted?
Old Aug 22, 2019 | 11:00 AM
wmmorrell's Avatar
2005 SL500 Designo Edition
Command Repair
I don't know if this place would be of any interest to anyone, I found it while doing some research on repairs/replacements.
http://www.hitechserv.com/electronic...nger-repair/80
Old Nov 18, 2019 | 02:45 PM
Lee Sargent's Avatar
2007 SL550
How do I tell which screen I have?
Old Nov 18, 2019 | 03:25 PM
Ivan750's Avatar
Mercedes SL r230
Hello, in Spain they change the screen, it cost me 250 euros to change the screen
Old Nov 18, 2019 | 03:28 PM
Post a picture and/or your VIN and someone will tell you.
Old Nov 18, 2019 | 03:52 PM
Dudeman's Avatar
Current: '07 SL550 & '14 GLK350. Previously owned: '06 ML350, '05 SL500, '99 ML320 & '98 SLK230 (RI
If anyone is interested I have a complete Comand head unit available for sale. Works great, the optical drive works fine, and the screen is very good condition, not burn-in or discoloration. I pulled it out of my 07 SL550 when I did a head unit upgrade to a Kenwood..
PM me if interested.
PS. I want to sell the whole unit, not just the LCD panel, so please don't ask me to part it.
Old Nov 20, 2019 | 02:23 PM
850csi's Avatar
--sold Sl55--
Not going to ask you to part it, but if it’s not too much trouble do you mind telling us the part number for the LCD screen?
Old Nov 20, 2019 | 03:14 PM
Dudeman's Avatar
I have no idea, without disassembling the Comand unit I can't tell what the part number is or even if there's a part number sticker on it.
Old Nov 20, 2019 | 09:34 PM
Speed750's Avatar
2005 SL500
First try and source the screen. Once you have the correct part, look for someone local to fix it . They're a ton of retired guys out there they used to fix TVs and stereos and now fix Bose stuff in their spare time. Somebody that's competent in fixing auto gear should have no problem fixing this deck. It's nothing special.
Old Feb 9, 2020 | 08:30 PM
850csi's Avatar
--sold Sl55--
So, in case it’s of any help to anyone...
I finally got around to pulling my COMAND unit and taking it apart. Not a terribly difficult or complicated job to get the display out. Here are pictures, looking into figuring out the right part.
(2008 SL55)
Old Feb 10, 2020 | 11:47 AM
850csi's Avatar
--sold Sl55--
Old Feb 10, 2020 | 08:26 PM
Speed750's Avatar
2005 SL500
Does the display have a uv filter ? Mine has a huge sunspot but one day with the top down and the sun directly behind me it went away..I could see the entire display, I was stoked. Then I moved the car and it came back. I know the guages have a polarization filter that can go bad. Any input ?
Old Feb 16, 2020 | 08:59 PM
850csi's Avatar
--sold Sl55--
So, new screen is in but it looks like the display is somewhat misaligned/cut off? Does anyone have any ideas?
Old Mar 1, 2020 | 01:55 PM
Ron Martin's Avatar
2003 R230 and 2007 W209
Guys,
I had some MAJOR scratches on my 2003 SL Command System screen after a "well meaning" detail shop '"cleaned" my screen!
The screen was so scratched that it was really not visibly use able. After trying to lightly clean/polish the screen .. I researched ALL the various options and upgrades from used command systems from other 03/04 R 230s .. since the 05 and newer are NOT interchangeable !
I read all the threads on this site and considered the large Chinese larger screen GPS reported replacements ..
Finally I realized the Command Screen internal display is projected onto a polarized surface film from a glass screen
I carefully scraped ALL the old FILM from the glass command screen and then ordered POLARIZED PFHC - AG/HC linear polarized film sheets from "A Flash"
Ste.108- 404, Shavano Park, Texas 78232 www.polarization.com for about $40 . The polarity works at a 45 degree angle to the projected image .. So measure the screen , take the peeled TOP polarized sheet and orient it to the desired angle and CAREFULLY cut it slightly larger than the viewed screen - (to slide under the edges).. BEFORE PEELING THE BOTTOM ADHESIVE. Then carefully work the new film onto your CLEAN OPAQUE screen .. and VOILA'
You can save a LOT of strife and keep your original system.
BTW this same fix should work on all later Command Screens since the have the same projection concept ..
Ron
Old May 25, 2020 | 08:24 PM
850csi's Avatar
--sold Sl55--
To follow up on this, I returned the screen and bought another one with a part no that matched exactly my original screen and everything lines up perfectly. Not sure if a quality control issue or what. Someone asked for some instructions and here’s what I can offer:
As far as tools I’m struggling to remember anything beyond a few different torx bits. you can find videos on YouTube of the COMAND unit being removed. It’s a little time consuming but not terribly difficult. IIRC 2005-2008 does not require the clock/ac vents to be removed.
Once the COMAND is out, the screen is actually the easiest part and fairly self explanatory. There are 4(?) screws that attach the faceplate/controls to the rest of the unit, and then a bunch of smaller screws to take off a couple of circuit boards.
got this additional info by PM — can’t verify
there are adjusting screws on the back of LCD screen V & H
they adjust height and width of the image on screen
Old Oct 28, 2020 | 11:36 AM
Torben C's Avatar
SL 550
Do you still have the command module?
Old Oct 28, 2020 | 06:51 PM
Dudeman's Avatar
Long gone I'm afraid.
Old Dec 2, 2020 | 02:51 PM
Paul Charles's Avatar
2007 sl550
hello, realize the post is old bt figured it was worth a try. available?
Old Dec 7, 2020 | 07:14 AM
Hendrik Koster's Avatar
Top Answer: 1
2007 S65 AMG-Sold, 2007 SL55 P030 - 2016 GL450 - - 2017 AMG GTS - Sold - 2015 AMG S65
Replacing Command screen
I can do replacements for 07-08 model command screens turn around time currently 2-3 days cost may depend on whether liquids have been spilled on the unit from the adjacent cup holders.
PM if interested.
Best H
