SL/R230: ABC Filter Maintenance
Old Oct 14, 2017 | 08:11 PM
JettaRed's Avatar
Veteran: Army
This summer, I started to get the dreaded ABC workshop warning, and then vehicle too low warning. So, I did a rodeo flush. But after about 500 miles, I started to get the overnight drop. So, I replaced all the seals and o-rings in the front valve block, which fixed the problem.
A couple of weeks ago, I would notice that when I started the car in the morning and began to drive, it seemed the front end would rise a little. This only happened when the car sat over night and not during the day. It is interesting because my car sits during the day as long as it does over night, so the temperature changes may have something to do with it.
I never got any warnings or anything, but I started to become concerned. It's been about 5500 miles since I rebuilt the valve block and 6000 since the rodeo flush. The previous owner had had two flushes at approximately 33,000 miles and 43,000 miles. I did my flush this summer at 62,500 miles.
Instead of a new rodeo flush, I decided just to swap the ABC filter since the hydraulic fluid is still good. I used an aftermarket filter of OEM quality. (Mercedes-Benz Hydraulic Self-Levelling Oil Filter W/ ABC Premium 0036101)
These are about $15 shipped versus the genuine MB filters. I'm figuring that if I want to replace filters every 5500-6000 miles, these will work. I figure that the hydraulic fluid will be good for a couple of years and that it is an unnecessary expense and waste of good CHF11s fluid.
It's been several days and absolutely no settlement or drop. I will keep everyone one informed if things should change, but I thought that I'd share this as a much cheaper and easier alternative to flushes or valve block rebuilds.
Old Oct 24, 2017 | 12:21 AM
knowbenz's Avatar
Benz
I think one of the issues is that you aren't circulating all the fluid all the time. There will always be some at the end of the line that just kind of sits there. Thats the stuff that gets nasty and eventually gets caught in the valves. I would definitely at least run the rodeo at intervals to help get as much of the old stuff back into circulation as possible
Old Oct 25, 2017 | 01:06 AM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
This makes me wonder if "exercising" the system is better than letting it sit unused. Almost every day, I use the center console button on mine to lift the car. Maybe this helps keep the fluid flowing?
Old Oct 25, 2017 | 05:27 AM
pfarah77's Avatar
2008 SL550
Funny, I do the same thing. Once in a while, the front will lift not totally even during rise but will stabilize at full extent. She will operate normally when I cycle through a second time so I typically hit the button 2-3 times and she seems happy...
Old Oct 27, 2017 | 12:09 PM
carguyshu's Avatar
2003 E55, 2003 SL55, 2014 CLS63, 2018 q50 Redsport, 1968 Camaro SS, 1999 Trans am Firehawk
according to the description that filter you bought only meets the micron spec for filtering of the old part number filter and not the new part number filter, which is 3 times better. I would ditch that thing immediately and buy an OEM one.
Old Oct 28, 2017 | 01:25 AM
JettaRed's Avatar
Veteran: Army
Can you be more specific? What's the new part number?
Old Oct 28, 2017 | 04:49 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
A0031846101 is the new style 3 micron filter. Personally, i do not buy parts new parts on eBay or Amazon. They may say Bosch or Fuchs, or even genuine MBZ, but are often cheap fakes.
Old Oct 29, 2017 | 02:29 AM
JettaRed's Avatar
Veteran: Army
Same part number for the aftermarket part. Not arguing your personal preference, but this one seems to be working well so far.
Old Oct 29, 2017 | 01:01 PM
bobterry99's Avatar
'09 S600, (2) R129 300SLs, '03 SL500, '03 SL55
You could probably drive for a year with no filter installed and not discern any effects; if so, then an inferior filter is unnoticeable.
I would stick with the Mercedes filter and change it when you change the fluid.
Old Oct 29, 2017 | 06:00 PM
carguyshu's Avatar
there's a reason merc switched from a 10 micron filter to a 3 micron filter. buy the genuine MB 3 micron filter. technically you could put in motor mounts from the base model on an AMG and they would fit, but they won't last very long. just because the filter fits doesn't mean its what you should be using.
