SL/R230: R230 350SL Front end knock.
Old Oct 23, 2017 | 12:01 PM
Mantaraman's Avatar
350SL
My recently-bought 350SL has a knock from somewhere underneath, consistent with ripples or bumps in the road. I've had it on a lift and the only item that looks doubtful is the front anti-roll bar bar drop links. The ball joint at the top would indicate that they are intended to rotate and there's only very minor play in the bushes at the bottom. Can't see anything else but does anyone have any advice?
I've found replacement drop links on several web-sites but there's no indication that bushes are included - again, can anyone shed any light on this?
Old Nov 4, 2017 | 06:56 PM
RLich8's Avatar
ABC
I just acquired a 2005 SL500 with 30k miles on it. On my initial road test, I noted an odd knock/creaking noise. The control arm bushings were bad and so were some other minor things like motor mounts and wheel bearings. I thought the noise would have been fixed by the control arms being replaced, but they werent. After having a technician put it back on a lift, he checked the torque of the subframe mounting bolts and they needed to be tightened. After retorquing those to factory spec, the noise was completely gone. You might have a look at that because it is an easy and free fix so long as you have the tools.
