SL/R230: For those of you that have steeriing wheel mounted buttons but wish you had paddles
Doing it using these paddle shifters you do not change out the shift switches but replace the plastic part you touch when changing gear with the shift paddles from Gordon
These shift paddles is made for the original button shifters and snaps on the shift switches like the outer plastc parts on the shift switches
Gordon Wright in the UK makes these paddles shifters that fit the switch shifters
You can buy paddle shifters that will fit your OEM steering wheel shift buttons from Gordon Wright. Homepage: g-paddles.com
Here are the email address: gpaddles@gmail.com
Here is a video that show you to do this 10 minutes job
The silver colored part is the only part that is going to be changed
Here are the button shifter after the shift switch is taken off
So you simply replace the silver colored plaastic switch with the paddle shiffters
These 3 pictures shows how to do this job
By adding a larger trigger it would improve accessibility but not improve overall transmission action
We owned a Golf GTI w DSG and I wish the SL was similarly equipped
Good Luck
Good Luck
However; like mentioned ^ speed and feel of shifts are still overly long and soft. The algorithms of a button/paddle car are better than stick only but honestly IMHO I wouldn’t bother.
If the paddles were stationary and at the outside edge of the wheel that would be great
I am aware that we are talking about a 5 G tronic standard automatic with a converter but i was not aware that the shift buttons / paddles where so slow
