SL/R230: Antifreeze questions
Old Nov 16, 2017 | 05:07 AM
Cashwowud's Avatar
350 SL
Hi Guys, I have owned my 2005 SL350 since 2006 and it has never had the coolant replaced. I know that in the owner manual it says every 15 years but why is this since usually you have to change the coolant every 4 years?
BTW, if I do decide to swop it is their anything special I need to know. I recently treated myself to a two post lift and so I have good access.
Thanks in advance,
cashwowud.
Old Nov 16, 2017 | 08:34 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
They use very good coolant and that's why the long change cycle. Likely your best bet for coolant replacement is Xerex G-05. It's compatible with MBX coolant and is readily available at most retail auto parts stores, and not too expensive. There's no secrets to changing it. Open the reservoir cap as a vent, and you can squeeze on the hoses to burp out as much as possible. After refilling, check it after several starts to top it off - it's self bleeding.
Old Nov 20, 2017 | 09:43 AM
Cashwowud's Avatar
350 SL
Thanks Rudeney for that info. I think I'll change it whilst it is on the lift.
cashwowud
Old Nov 28, 2017 | 01:32 PM
carguyshu's Avatar
2003 E55, 2003 SL55, 2014 CLS63, 2018 q50 Redsport, 1968 Camaro SS, 1999 Trans am Firehawk
this article explains everything quite well
https://www.google.com/url?sa=t&rct=...QYY-x4ot3W4ma3
