SL/R230: R230 headlights
Old Nov 16, 2017 | 08:30 PM
Talon1381's Avatar
08 sl55 amg
R230 headlights
Does anyone know where I can get a replacement harness for inside the Bi- xenon headlights, the wire insulators are cracking and disintegrating and I don't want to buy a whole new headlight with igniters and ballasts for just a bad harness
Old Nov 17, 2017 | 10:02 AM
Heatwave's Avatar
Veteran: Navy
2007 E350; 2018 GLE350
Talon: you might consider "painting" the exposed wiring with Liquid Tape. Works.
Old Nov 19, 2017 | 10:28 AM
Talon1381's Avatar
08 sl55 amg
I'll give that a try thanks
Old Nov 24, 2017 | 04:46 PM
TTtodd's Avatar
2005 SL65
The big question for me would be why on a MY2008 would the insulation be deteriorating to the point it needs replacement.
Old Nov 24, 2017 | 04:56 PM
Racin_fool's Avatar
2008 E63 wagon (1 of 62)
heat cycling is the biggest cause combined with probably cheap wiring/insulation.. Mercedes used to have engine harness insulation issues pre-1995 or so, but they changed the processes since then and they no longer have those issues. The insulation on the wiring in the headlamps probably isn't as durable when compared to the newer engine wiring harnesses.
Also, if you dont think your headlamps get hot, turn on your lights (xenon/halogen) and hold your hand infront of the car on the lens and you will feel it get warm pretty quickly.
Old Feb 26, 2019 | 10:28 PM
DJErikD's Avatar
2007 SL55 AMG
Same problem here. Anyone find a solution other than new headlights or rewiring the old, brittle connectors?
Old Feb 27, 2019 | 04:19 AM
Talon1381's Avatar
08 sl55 amg
I wish there was I ended up buying new ones
Old Mar 15, 2019 | 07:00 PM
Frederick NL's Avatar
2005 R 230 SL350 (M112 3.7). Sold the 1966 W113 230SL recently
My headlights are crystal clear, like new. Should I do something about keeping them as clear in the (long)er run? I use anti freeze that explicitly states it is safe for plastic head lights. How about applying car wax?
(bi-xenons - can wax cause an irritating flare for head on traffic?)
Old Mar 15, 2019 | 08:10 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Why not cover them with 3M clear bra?
Old Mar 15, 2019 | 08:42 PM
Hendrik Koster's Avatar
Top Answer: 1
2007 S65 AMG-Sold, 2007 SL55 P030 - 2016 GL450 - - 2017 AMG GTS - Sold - 2015 AMG S65
Source...
Can you recommend a source for for pre-cut 3M clear for the head lights?
Thx
Old Mar 15, 2019 | 09:31 PM
Aussiesuede's Avatar
SL500 & GL450
This ceramic coating works great. https://www.mckees37.com/headlight-coating.html#
Old Mar 15, 2019 | 10:47 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Not sure about pre-cut , bu you can buy sheets of 3M clear-bra. Just so it on a nice, hot day. Let the clear bra and the car sit out in the sun for about 30 minutes, start at the center and stretch to the edges.
Old Mar 16, 2019 | 03:54 AM
alk247's Avatar
2003 SL500
I understand that headlights are actually covered with clear coat. This guy shows how to restore the clear coat on the headlight. Look though videos on his channel for one with headlights.
https://www.youtube.com/channel/UCT5...uy041dbWPB6skg
Old Jan 24, 2026 | 07:11 AM
cnbaan69's Avatar
Hi, I got the same problem with my SL550 (R230, 2007) the harnesses of nearly all wires are disintegrated for 50% and are now creating a short-circuit for the parking lights.
Were you able to solve the problem with a replacement harness? If yes, do you have a contact?
Thanks a lot, chris
Old Jan 24, 2026 | 08:57 PM
mrvedit's Avatar
2004 SL600
There are two "Mercedes R230 headlight harness" on Ebay right now, although they say they are for 2003-2006; don't know if it would fit a 2007.
I changed the search to "2007 mercedes r230 headlight harness" and got very different results, including pigtails that might do what you need.
