SL/R230: Trickle Charger
Old Jan 8, 2018 | 04:04 PM
JohnZSL550's Avatar
09 SL550
Trickle Charger
Question for a 2009 SL550, which battery do I hook a trickle charger up to, the starter battery under the hood or the one in the trunk? I have not had any trouble with the starting of the car yet but the accessory battery in trunk is getting low as the ESP light sometimes stays on after not running for a couple days and the seat heaters flash until car runs for a while and re-charges the battery. Thanks
Old Jan 8, 2018 | 06:52 PM
next2pool's Avatar
2003 SL500, 2016 ATS, 2016 CTS 2015 Volt
Trunk Battery.
Old Jan 8, 2018 | 08:02 PM
carguyshu's Avatar
2003 E55, 2003 SL55, 2014 CLS63, 2018 q50 Redsport, 1968 Camaro SS, 1999 Trans am Firehawk
also, the trickle charger should be designed for an AGM battery. on the ctek the winter mode (graphic is of a snowflake) is the one you are supposed to use for AGM batteries. the front battery is a standard lead acid battery and the only thing it does is run the starter, nothing else. with no small drain on it the starter battery should remain charged for quite some time without needing a maintainer.
