SL/R230: Ride question
I am a new owner of an '03 SL500s with just 50K on the clock. I spent a good bit of time researching before I bought the car and did have it checked out at a dealer prior to purchasing. All was good except for a TPS transmitter in one tire. I do have a question about the ride. With the car in the "high" setting and the ABC on it's softest setting, the car seems to want to fishtail a bit when going over bumps in the road. No ABC warnings or lights, no leaks in the system, fluid right on the marks and tires are stock. I have other sports cars and have not experienced this. Any help or thought would be appreciated.
So would worn bushings in the suspension. The front / lower / inside bushings are only 50K mile parts before they wear and tear and need replacing.
My SL55 has the fishtail issue, but I need the left rear toe in setting adjusted, so I attribute it to alignment after adding the adjustable camber links.
Always check the the simple things first!
