SL/R230: Knocking Engine Sound SL550
Old Mar 14, 2018 | 06:04 PM
JaxDave's Avatar
SL550
Question Knocking Engine Sound SL550
I recently got my SL550 back from the dealer for service. One of the issues was what I described as a "Ticking" sound. They did not find anything wrong, but found some other issues that would have cost me $2300. Fortunately, I had a warranty to cover the cost. NOW, there is a Knocking Sound coming from the Right Side (it seems) of the engine when facing the front of the car. It does not attenuate with RPM. And there is no indication of an issue from the Command Display. I've attached a small video which when listen to, the knocking can be heard. The dealership said that it did not make that noise when they returned the car. But when they did return the car is the first time that I have heard this noise. I have since arranged for a retired MB Service rep to investigate (has his own shop now). Hopefully, I can attach the video with sound. Any clues would be very much appreciated.
Old Mar 14, 2018 | 06:11 PM
JaxDave's Avatar
SL550
FYI. It turned out to be the ABC Damper on the ABC Pump. "Found Pressure Reservoir Dampener on ABC noise coming from the ABC Pump." Just in case anyone has the same problem.
Old Mar 15, 2018 | 04:29 PM
pfarah77's Avatar
2008 SL550
Ouch... Did you have to replace the pump?
Old Mar 16, 2018 | 05:48 AM
JaxDave's Avatar
SL550
Smile
Actually, I had the Pump replaced a week or so earlier (wondered if that hand anything to do with the knocking problem?), and it was all under the warranty that I had purchased when I bought the car.
