SL/R230: parking brake
http://benzbits.com/w209/ParkingBrakeAdjustShoes.pdf
Many thanks for quick reply. The lug bolt holes do not line up with the star wheel adjusters. It looks as though the parking brake drum needs to be removed to gain access to the adjusters. My SL is a 2002 R230 model.
Will adjust the parking brake as you suggest. Will let you know when job is done
Tony Smith
You might have to replace the brake shoes, If i first have the rear brake calipers and rotors off i suppose i would change the brake pads anyway if they are a bit worn.
The brake shoes for the park brake does not cost much
