SL/R230: Engine Noise
Old Jun 14, 2018 | 10:28 AM
viper1996's Avatar
sl500
Engine Noise
My 03 runs great but on idle it has a cycling sound like a washing machine...it is not that bad but curious as to what it could be...Thanks
Old Jun 14, 2018 | 09:45 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Is it an actual noise or a "feeling"? Maybe bad motor mounts?
Old Jun 17, 2018 | 01:04 PM
viper1996's Avatar
sl500
I did replace the motor mounts, one was collapsed...You can feel it and hear it...Off idle its fine...It is slight but noticeable...Thanks...
Old Jun 17, 2018 | 01:46 PM
fooschnickens's Avatar
2004 SL500
Did you check the trans mount as well? Usually a good idea to go ahead and do both at the same time as one failing will wear out the other that much faster.
Old Jun 17, 2018 | 09:05 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Did it just recently get very hot where you live? I've always found that MBZ engines just don't like extremely hot and humid weather. My SL550 idles jsut a bit less smoothly in the summer, as did my CLK550's. I had an ML320 that absolutely hated hot/humid weather - it would sometime even die at idle. Neither I not the dealer ever found out what caused it as everything was "normal and in spec" until ti would die.
Old Jun 20, 2018 | 07:55 AM
viper1996's Avatar
sl500
Def not the heat....gonna take a look at the tranny mount...
Old Jun 20, 2018 | 08:50 AM
2004 SL500
You can also do the old broomstick test and see if it's any of the accessories that are grinding or part of the engine itself. I know on my W210 the tensioner pulley was a bit of a weak point, but that usually squeaked rather than the chugging sound you're describing.
Old Jun 20, 2018 | 01:25 PM
Noir230's Avatar
1992 400E, 1997 SL500, 2007 SL55 AMG, 2016 E400
Have you had the noise all along? If so, it may be normal supercharger noise. They're quite noisy. I took my car to a MB-only indy when I first got it who told me it's normal. ** Sorry, I just assumed your car is an AMG and I just noticed it doesn't say which model you have.** Never mind.
Old Jun 21, 2018 | 08:29 AM
viper1996's Avatar
sl500
Ha, Wish I had a blower to be noisy...Car sounds fine when listening under the hood...So I think the tranny mount is the culprit...After I check I will post findings...
Old Jun 21, 2018 | 05:07 PM
makterna's Avatar
SL500 2006
My M113 engine has a valve ticking noise which can only be heard at certain RPMs. According to other threads, it is old oil/carbon deposits on the valve/valve seats. Some say changing the oil to Mobil 1 fixes it, but in my case there was no difference.
If this is true, how do we get rid of those deposits? I recently did a CataClean, which worked and fixed my check engine light by cleaning the cats from soot deposits. Not sure if it is supposed to fix valve tick too but anyhow, it didnt, at least not in my case.
