SL/R230: where is the fuse located
2005 Mercedes SL
I have a 2003 SL and the drivers seat still works but not with the 1,2 or 3 memory button. I even tried reprogramming the settings. Could it be a fuse and where would that be located.
Also when the memory button is depressed the rear view mirror moves into it's save memory spot.
MBworld Guru
This isn't a fuse issue since other functions of both the door controller (the seat buttons) and the seat controller (moving the seat) are working. It's either an issue with the memory buttons (maybe their wiring harness is not properly connected to the door controller?) or the seat controller is malfunctioning and not accepting the memory commend. Doe you get a beep when you set the memory position? If so, then the door controller and buttons are working, so it would be a seat controller issue.
2005 Mercedes SL
I'm not proficient in the forum, hopefully I am responding to you correctly. I do not get a beep, but never have. I also forgot to mention the buttons on top of the seat the move it forward/back to allow easier access to the rear compartments also stopped working at this same time.
Sounds like a position sensor or other fault happened in the seat and normalization is lost, the seat can still move but doesn't know exactly where it is, so the memory and auto-fold are out. Did you happen to change a battery before this happened? I'd have it scanned and have the seat position re-learned.
2005 Mercedes SL
![Thumbs up](https://mbworld.org/forums/images/icons/icon14.gif)
![Boink](https://mbworld.org/forums/images/smilies/boink.gif)
I'll take it to my guy :-). Thanks all!
MBworld Guru
I concur with Joe. You could try unplugging the power lead to the seat controller to see if it resets. If not, it may need to by hooked up to SDS to re-normalize it.
