SL/R230: Need to identify a reservoir
Old Jun 29, 2018 | 06:36 PM
China Joe's Avatar
SL 500
There is a small reservoir behind the ABC filter/reservoir in my 2005 500SL that is not identified and I'm not sure what kind of fluid it takes.
The cap is black, flat, bumpy edges - no writing - has a short dipstick attached to the cap. Fluid appears light yellowish brown on a paper towel.
Old Jun 29, 2018 | 09:10 PM
moretech's Avatar
2003 sl 500
reservoir
Power steering reservoir. Use pentosin 11s
moretech
Old Jun 29, 2018 | 09:47 PM
Joe Fung's Avatar
sl500
Thank you.
my next question is why the hydraulic oil is not green.
i just have the sl for a year,
i did change the ABC oil and filter today.
thanks for your help.
Old Jun 29, 2018 | 09:58 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
If it wasn't green before you changed it, it's because it was dirty. If it;s not green now,then you used the wrong fluid - Pentosin CHF 11s is definitely green.
Old Jun 30, 2018 | 09:51 AM
Joe Fung's Avatar
sl500
the front ABC system has been activating on its own. Most often when I slow down or come to a stop. I flushed it and changed the filter, but it still happens. Do you have any thoughts on what else could be causing it?
Could it have anything to do with low levels in the power steering fluid?
Old Jun 30, 2018 | 12:30 PM
moretech's Avatar
2003 sl 500
front end movement
I doubt power steering has anything to do with it. Much more likely is the control valve assembly O rings need replacing. For my '03 model the assembly is on the drivers side just behind the front bumper and not too hard to remove. Many hose connections are involved that need to go back in the holes they started in, need to mark them carefully. I am not sure for an '05 if there are model year variances that come up to cause a problem in removing the assembly. Many threads are in the forum on this topic of O ring replacement. Other members may chime in here using diagnostic codes from a STAR scan tool that may aid in determining the exact cause of your problem.
moretech
Old Jun 30, 2018 | 02:30 PM
Joe Fung's Avatar
sl500
Thank you.
I think you are right about the valve block needs new rings and clean.l have been reading a lot of information here before decided to join .
I will do more study on how to replace and clean the valve block first.any advice can be helpful from all of you, thanks again,
