SL/R230: Alarm Fuse
Old Jun 30, 2018 | 08:52 PM
sjv123's Avatar
SLK 230
Alarm Fuse
I am having the same alarm screeching issue, so I opened the fuse box but nothing is indicated for an alarm fuse. Which one is it? I have a 20004 SLK.
Old Jun 30, 2018 | 09:40 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
You're in the wrong forum - your 2004 SLK is an R170.
Old Jun 30, 2018 | 10:16 PM
bobterry99's Avatar
'09 S600, (2) R129 300SLs, '03 SL500, '03 SL55
Originally Posted by sjv123
...I opened the fuse box but nothing is indicated for an alarm fuse.
There is no fuse for the alarm. What you can do is unplug the siren. The connector is located under the fuse box, is yellow in color, and has a yellow/red wire and a brown wire.
Old Jul 25, 2019 | 07:00 PM
Mick67t's Avatar
2001 SLK230
I don't remember which number, but the fuse for the alarm system is in the fuse box near the driver's side hood hinge. The fuse box cover should have a sticker that says which fuses are which systems.
