SL/R230: 2007 MB SL350 R230 in car stereo/sat nav upgrade
i've since seen others install pioneers and alpines in their SL's but i wanted the factory look, and i think the Seicane did it.
seicane is aliexpress
all those sites come from aliexpress
better buy on ali
Removal of the Command and replacement with an Android system can affect the steering wheel controls and definitely won’t work the stock surround set up (that’s assuming you have that set up). That means you’ll end up having to potentially remake all the speaker connections and add aftermarket amps etc.
I chose to have a Dension 500 system installed which mimics the CD Changer through the MOST system. Works seamlessly and with my iPod classic and also iPhone.
It can be a bit clunky to navigate through the song menus on the Command but once you learn how to do it, it’s perfect, for what I want. Looks totally stock, steering controls all work, uses OEM system so surround features are retained and it also displays all the song info on the Command interface.
