SL/R230: Dealer Issue
So I call the dealer and explain my circumstances with they request that the car be brought back for inspection and they made an appointment ( 7 weeks wait ). I'm assuming now that a valve lifter may be the culprit, so i don't drive it for the 7 weeks. I also assumed that since this ticking issue occurred while the car was in the dealers possession, that they'd take care of it. That was my impression. I was wrong. The car is currently at the dealers and I'm contacted by service rep that there will be a 3 hour diagnostic charge to pull the valve cover to inspect. I replied, do what ever you have to do to find the issue as it's on your time. Dealer replies that they not covering any of the costs. So Is it written in Mercedes Benz terms and conditions that they are not responsible for damages occurred while a clients vehicle is in their possession? Plus I think a 200 km plus test drive is a bit excessive is it not? I personally think the tech took the car and ran the crap out of it. So my question is...If it is a lifter or valve damage, is it my responsibility to cover all the repairs? I'm thinking this may be an expensive fix and I'll be on the hook for 100% of the cost. Any input is appreciated.
Not that I am defending the dealer, but mechanical parts will fail. If your engine has developed a lifter problem, it is very unlikely that the dealer caused it. It's most likely just an unfortunate coincidence. I do think that putting 200kms on the car for "testing" is a bit excessive.
It tore up the lower front clip.
while at the dealer body shop it when in and out of the body shop to their parking lot waiting for parts.
When finished at the body shop it was driven to the service center , about 1/2 mile away, to get a front end alignment.
When I went to pick up the SL the check engine light was on.
I asked why this car was driven with a check engine light and it’s not mentioned in any paperwork nor did anyone notify me.
They tried to say it came in that way which it did not!
I then asked for an estimate for the repair.
The estimate was $6,700!!
It showed replacing both coil packs, control box and spark plugs.
I said NO THANKS!
I drove the car home, no power, and purchased an control box after trouble shooting with Clark from V12ipack and
spent $600.00 to take care of the problem.
